Prove only group homomorphism between Z5 and Z7 is the trivial one.
  • Thread starter Thread starter mahler1
    Group
The only homomorphism between the groups Z5 and Z7 is the trivial homomorphism ψ(x) = 0. This conclusion is derived from the properties of group homomorphisms and the fact that gcd(|Z5|, |Z7|) = 1, which implies that any non-zero element in Z5 cannot map to a non-zero element in Z7. The proof demonstrates that since 5 is not congruent to 0 modulo 7, ψ(1) must equal 0, leading to the conclusion that Hom(Z5, Z7) = 0.
  • Understanding of group theory, specifically homomorphisms
  • Familiarity with modular arithmetic and congruences
  • Knowledge of Lagrange's theorem in group theory
  • Basic properties of the greatest common divisor (gcd)
  • Study the implications of Lagrange's theorem in finite groups
  • Explore the structure of cyclic groups and their homomorphisms
  • Learn about the properties of gcd in relation to group homomorphisms
  • Investigate other examples of trivial and non-trivial homomorphisms between different groups
Mathematics students, particularly those studying abstract algebra, group theory, and anyone interested in understanding the properties of homomorphisms between finite groups.
mahler1
1. Homework Statement .
Prove that the only homomorphism between Z5 and Z7 is ψ(x)=0 (the trivial homomorphism).
3. The Attempt at a Solution .
I wanted to check if my solution is correct, so here it goes:
Any element x in Z5 belongs to the set {0,1,2,3,4}
So, I trivially start by saying that ψ(1)=ψ(1) and then, using the fact that ψ(x+y)=ψ(x)+ψ(y), I get:
ψ(2)=ψ(1+1)=ψ(1)+ψ(1)=2ψ(1)
ψ(5)=ψ(1+1+1+1+1)=ψ(1)+ψ(1)+ψ(1)+ψ(1)+ψ(1)=5ψ(1)
But 5=0 (mod 5) and, as ψ is a homomorphism, it must be 0= ψ(0)=ψ(5).
By transitivity, 0=5ψ(1) (mod 7) but 5≠0 (mod 7), then ψ(1)=0. But ψ(x)=xψ(1)=0 for all x in Z5, hence Hom(Z5,Z7)=0.
I think this last line needs to be spelled out a little more, essentially you have claimed that 5x = 0, and since 5 is not equal to 0 that x is equal to 0. There exist rings where you can multiply two nonzero numbers and get a zero, so you should probably explicitly prove that you're OK in Z7 unless this is something you've already done in your class
Hint : You need to use the fact that :
##gcd(|\mathbb{Z}_5|, |\mathbb{Z}_7|) = 1##
as well as Lagrange's theorem.
Yes, I see what you mean. If I am in Z6, 3≠0 (mod 6) but from 3x=0 (mod 6) I can't conclude that x=0 (mod 6) as any x even would satisfy 3x=0 (mod 6). In the original problem I could say x=0 (mod 7) just because gcm(5,7)=1. I am not so sure how to prove what I've claimed, I'll check it. Thanks.
prove: the only factorization of 5 as a product of a factor of 5 and a factor of 7 is 5.1.
  • · Replies 16 ·
