Prove that Casimir operators commute with the elements of Lie algebra
The discussion revolves around proving that the Casimir operators commute with elements of a Lie algebra, specifically focusing on the expression ##[C, a_{r}] = 0##. The context is set within the framework of semi-simple Lie algebras and involves manipulating the definitions of the Casimir operator and the structure constants.
  • Participants explore the manipulation of the Casimir operator's definition and its relationship with the structure constants. Questions arise regarding the validity of certain algebraic manipulations and the definition of the Casimir operator itself. Some participants suggest considering the invariance of the bilinear form associated with the Casimir operator.
The discussion is ongoing, with participants sharing their attempts to manipulate expressions and clarify definitions. Some guidance has been offered regarding the properties of the Killing form and the adjoint representation, but no consensus has been reached on the next steps or the validity of specific approaches.
There are references to different definitions of the Casimir operator, specifically regarding the use of the inverse of the metric tensor ##g_{ij}##. Participants are also considering the implications of the semi-simple nature of the Lie algebra on the structure of the problem.
JTFreitas
Consider a vector space of dimension ##n## of a semi-simple Lie algebra ##\mathcal{L}## with basis ##{a_1, a_2, ..., a_n}##, and the composition law:
$$ [a_r, a_s] = \sum_{p = 1}^{n} c_{rs}^{p}a_{p} $$
Prove that the Casimir operator acting on the vector space commutes with all the elements of the Lie algebra, ##a_r##:
The Casimir operator ##C## is defined as
$$C = \sum_{i,j} g_{ij}a_{i}a_{j} $$
where
$$g_{ij} = \sum_{l,k}c_{ik}^{l}c_{jl}^{k} $$
Where the numbers ##c_{rs}^{p}## are the structure constants of ##\mathcal{L}##, defined according to
$$[a, a_{s}] = \sum_{p = 1}^{n} \text{ad}(a)_{ps}a_{p} $$
and
$$[a_{r}, a_{s}] = \sum_{p=1}^{n} c_{rs}^{p}a_{p}$$
which implies that
$${\text{ad}(a_r)}_{ps} = c_{rs}^{p}$$
I want to show that ##[C, a_{r}] = 0##. This means that:
$$ Ca_{r} - a_{r}C = \sum_{i,j} g_{ij}a_{i}a_{j}a_{r} - a_{r}\sum_{i,j} g_{ij}a_{i}a_{j} = 0$$
I don't understand what manipulating I can do here. I have tried to rewrite ##g_{ij}## in terms of the structure constants:$$\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}a_{j}a_{r} - a_{r}\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}a_{j}$$
Now, I am not sure I can do this, since ##a_r## isn't necessarily part of the sums, but I know that
$$a_{j}a_{r} = [a_{j}, a_{r}] + a_{r}a_{j}$$
Hence the expression becomes
$$\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}([a_{j}, a_{r}] + a_{r}a_{j}) - a_{r}\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}a_{j}$$
And based on the composition law, the expression becomes
$$\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}\left(\sum_{p = 1}^{n} c_{jr}^{p}a_{p} + a_{r}a_{j}\right) - a_{r}\sum_{i,j}\sum_{l,k}c_{ik}^{l}c_{jl}^{k}a_{i}a_{j}$$
And this is where I am completely out of ideas about tackling the expression.
Is my work up to this point even valid? Any pointers on how to proceed from here would be very much appreciated.
##C = \sum_{i,j} g_{ij}a_{i}a_{j}##
where
##g_{ij} = \sum_{l,k}c_{ik}^{l}c_{jl}^{k}##
Is this really how ##C## is defined? My references use the inverse of ##g_{ij}## in the definition of ##C##.
Thank you for taking a look at it.
I just double-checked, and according to my textbook, it is defined with ##g_{ij}## as is.
We have to show that ##C(X)\in \operatorname{Z(U}(\mathfrak{g}))##. Wikipedia mentions that this is due to the invariance of the bilinear form the Casimir operator is defined by (which also might explain the two different definitions in your and @George Jones' book). In the case above it is the Killing-form ##\operatorname{B}(X,Y)=\operatorname{trace}(\operatorname{ad}(X)\circ \operatorname{ad}(Y))## of the semesimple Lie algebra ##\mathfrak{g}.## Thus invariance means
B(\operatorname{ad}(Z)(X),Y)= B([Z,X],Y)=-B(X,[Z,Y])=-B(X,\operatorname{ad}(Z)(Y))
where the Casimir operator is given by ##C=\sum_{i=1}^n a_iB(a_i,-).##I assume if you take these equations and fight your way through the coordinates, then you will be able to prove that ##C(X)## is in the center of ##\operatorname{U}(\mathfrak{g})## for all ##X\in \mathfrak{g}.##
JTFreitas said:
Homework Statement:: Consider a vector space of dimension ##n## of a semi-simple Lie algebra ##\mathcal{L}## with basis ##{a_1, a_2, ..., a_n}##, and the composition law:
Relevant Equations:: The Casimir operator ##C## is defined as
where
and
which implies that
Since your Lie algebra is semi-simple, can you choose a basis such that ##g_{ij}## has a particularly nice form?
It already has a particularly nice form, namely the Killing form. I am pretty sure it would be a lot easier to prove without coordinates, just using the adjoint representation and the fact that the Killing form is non degenerate.
  • · Replies 17 ·
  • · Replies 31 ·
