Prove that phase-conjugate waves satisfy Maxwell's equations
8 replies · 3K views · last reply
Haorong Wu
Let ##\mathbf E =\mathbf E_0 ( \mathbf r) e^{-i \omega t}##, ##\mathbf H =\mathbf H_0 ( \mathbf r) e^{-i \omega t}## be some solutions of the Maxwell equations. If the medium is not absorbing, then prove that the phase-conjugate waves $$\mathbf E_{PC} =\mathbf E_0^* ( \mathbf r) e^{-i \omega t}, \mathbf H_{PC} =\mathbf H_0^* ( \mathbf r) e^{-i \omega t} $$ also satisfy the Maxwell equation.
Maxwell equations
This is the second part of a problem. In the first part of the problem, I have proven that ##\mathbf E^* =\mathbf E_0^* ( \mathbf r) e^{i \omega t}## satisfies the Maxwell equations.
Then, in this part of the problem, I tried to first prove that ##\mathbf E^{'} =\mathbf E_0 ( \mathbf r) e^{i \omega t}## satisfies the Maxwell equations, since by conjugation, the waves in the question would satisfy the Maxwell equations.
Now, ##\mathbf E^{'} =\mathbf E_0 ( \mathbf r) e^{i \omega t}=\mathbf E_0 ( \mathbf r) e^{-i \omega t}e^{2i \omega t}=\mathbf E e^{2i \omega t}##. Similarly, ##\mathbf B^{'} =\mathbf B e^{2i \omega t}##.
Substitute them into ##\nabla \times \mathbf E + \frac {\partial \mathbf B} {\partial t}=0## yields $$(\nabla \times \mathbf E)e^{2i \omega t}+ \frac {\partial \mathbf B} {\partial t} e^{2i \omega t} + \mathbf B \cdot 2i \omega e^{2i \omega t} =0$$
Since ##\mathbf E =\mathbf E_0 ( \mathbf r) e^{-i \omega t}##, ##\mathbf H =\mathbf H_0 ( \mathbf r) e^{-i \omega t}## are some solutions of the Maxwell equations, then ##(\nabla \times \mathbf E)+ \frac {\partial \mathbf B} {\partial t} =0##, leaving $$ \mathbf B \cdot 2i \omega =0$$.
I do not know where I did wrong.
##\mathbf B## is only function of ##\mathbf r##
I am sorry I do not follow you. ##\mathbf B## is proportional to ##\mathbf H##. Since ##\mathbf H =\mathbf H_0 ( \mathbf r) e^{-i \omega t}##, ##\mathbf B## should depend on ##t##, as well.
vanhees71 said:
In this case all fields are assumed to be time-dependent by a factor ##\exp(-\mathrm{i} \omega t)##.
Thanks!. But I am sorry I am not familiar with the expression that "be time-dependent by a factor". Do you mean the fields need the extra phase-term?
The idea is to consider fields with harmonic time dependence, i.e., for any field ##f## and ansatz is made of the form
$$f(t,\vec{x})=f_0(\omega,\vec{x}) \exp(-\mathrm{i} \omega t).$$
Does this type of field represent a monochromatic wave?
I don't like "monochromatic", but yes, it's often expressed in this way. One should however be aware of the fact that color is a physiological notion, which is much more complicated than the frequency of a plane-wave mode of the electromagnetic field!
I solved the problem in other way. I noted that the phase-conjugate wave travels in the opposite direction, or equivalently, travels with a time-inversal. So the time derivatives in the Maxwell equations become ##\partial _{-t}##. Then the problem is solved.
I am not sure whether this method is connected to your statement.
Thanks, @vanhees71 .
