Prove that the function given with f(x) is a PDF
8 replies · 3K views · last reply
MrKushtrim
Hi,
Could someone help me prove that the function given with
##f(x) = \binom{x-1}{r-1} p^{r}(1-p)^{x-r}## is a probability density function, where ## x= r, r+1,..., \infty ## and ## 0<p<1 ##
I thought to solve it somehow by using the binomial theorem, but since it's the upper part that's changing on the binomial coefficients, this proved futile.
Let's start simple:
Can you prove that the value is always larger than zero?
MrKushtrim said:
Hi,
[tex]f(x) = \binom{x-1}{r-1} p^{r}(1-p)^{x-r}[/tex] is a probability density function, where [itex]x= r, r+1,..., \infty[/itex] and [itex]0<p<1[/itex]
You need to show that [tex]\sum_{x=r}^\infty \binom{x-1}{r-1} p^r (1-p)^{x-r} = 1.[/tex] Setting [itex]q = 1- p[/itex] and [itex]m = x - r[/itex] gives [tex] \sum_{x=r}^\infty \binom{x-1}{r-1} p^r (1-p)^{x-r} <br /> = (1 - q)^r \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m.[/tex] What does the series on the right have to equal if the left hand side is to equal 1, and can you prove that it does?
MrKushtrim said:
Hi,
$f(x) = \binom{x-1}{r-1} p^{r}(1-p)^{x-r}$ is a probability density function, where $x= r, r+1,..., \infty $ and $0<p<1$
For discrete random variables, I prefer to use symbols like ##j## and ##k## instead of ##x##. So, in this notation: what properties must be possessed by
[tex]f_k = {k-1 \choose r-1} p^r (1-p)^{k-r}, \, k = r, r+1, r+2, \ldots[/tex]
in order that it be a legitimate probability mass function of a discrete random variable? Note that ##f_k## is NOT a probability density function; it is a probability mass function. There is a world of difference!
Hi, thanks for the reply .
It must equal 1. Though I have no idea how to prove it.
Thanks, I had the terminology mixed up.
To be a probability mass function , ##f_k## has to be positive, and the sum over all ## k ## has to be 1.
It's easy to see that ##f_k## is positive, but I cannot seem to prove the second property
Remember, you need to show that
[tex] (1 -q)^r \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = 1[/tex] for every [itex]0 < q < 1[/itex]. This suggests that the series [tex]\sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m[/tex] must be the binomial expansion of ... what function of [itex]q[/itex]?
## \frac{1}{(1 -q)^r } ##
But how would I prove that ?
Edit:
I checked a wikipedia article about binomial series, and it turns out that the series [tex]\sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m[/tex] is of this form , where ##β= r-1## and ##z=q##
Thanks for the help :)
Though, is there any other way to prove it, without directly using the formula ?
Edit:
Ultimately the only way to sum power series is to relate them to power series of known functions.
There are other ways of showing that [itex]\sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = (1 - q)^{-r}[/itex]. For example, using the formula [tex] \frac{d^k}{dx^k} \left( \sum_{n=0}^\infty a_n x^n \right) <br /> = \sum_{n=0}^\infty a_{n+k} \frac{(n + k)!}{n!} x^n[/tex] we see that [tex] \sum_{m=0}^\infty \frac{(m + r - 1)!}{(r-1)!m!}q^m = \frac{1}{(r - 1)!} \frac{d^{r-1}}{dq^{r-1}} \left( \sum_{m=0}^\infty q^m \right).[/tex] [itex]\sum_{m=0}^\infty q^m[/itex] is a geometric series and is easily summed.
