Prove that the gradient is zero at a local minimum.
7 replies · 11K views · last reply
Bosley
Suppose F: Rn --> R has first order partial derivatives and that x in Rn is a local minimizer of F, that is, there exists an r>0 such that
f(x+h) [tex]\geq[/tex] f(x) if dist(x, x+h) < r. Prove that
[tex]\nabla[/tex] f(x)=0.
We want to show that fxi(x) =0 for i = 1,...,n
So we want to show that [tex]\lim_{t\to 0}\frac{f(x + t e_i) - f(x)}{t} = 0[/tex]
Where [tex]e_i[/tex] is the ith standard basis element.
We know f(x+h) [tex]\geq[/tex] f(x) if ||(x+h) - x|| <r, that is, if ||h|| < r.
Consider |t| < r. Then ||t ei|| = |t| < r.
So then f(x) [tex]\leq[/tex] f(x + t ei) for all t such that |t| < r, and f(x+t ei) - f(x) [tex]\geq[/tex] 0.
But I don't know where to go from here...insight?
There may be a better way of doing this. In particular, let [itex]\hat x \in\mathbb R^n[/itex] be your minimum. Define the function [itex]g: \mathbb R\to \mathbb R[/itex] by [itex]g(t) = F(\hat x+te_i )[/itex].
What can you say about the minima of g? How does this help you?
Well, the minima of g would occur where
[tex] g'(t) = \frac{dF}{dt}(\hat{x} + t e_i) = 0[/tex] I suppose, but I'm not sure how to employ that. Can you give me a little more of a hint? I'm not seeing what we can say about the derivative of F with respect to t, I guess.
Well, the minimum of F is [itex]\hat x[/itex] right? So any other value of x would give [itex]F(x) \geq F(\hat x)[/itex]. In particular, what if we set [itex]x = \hat x + t e_i[/itex]?
If that's still too esoteric, what happens to [itex]g(t)[/itex] when we let [itex]t=0[/itex]? What happens when [itex]t \neq 0[/itex]?
My tex code got screwed up and then I had to step away from the computer so I deleted it. Anyway:
g(0) = f([tex]\hat{x}[/tex])
g(t) = f([tex]\hat{x} + t e_i[/tex]) where [tex]t \neq 0[/tex]
So [tex]g(t) \geq g(0)[/tex] for all t.
But how is this different from what I originally had, which is that [tex]f(x + te_i) \geq f(x)[/tex]? I'm sorry I'm having so much trouble putting together your hint.
It's okay.
The point here is that g has a minimum at 0. So in particular you can show very easily that [itex]\left. \frac d{dt} \right|_{t=0} g(t) = 0 [/tex], since this is only one dimensional right? I'm not sure if you're allowed to assume this, but it's fairly easy to prove and you don't need to use vectors.<br /> <br /> Now try finding g'(0) in terms of F.[/itex]
Aha. I think I get it. Is this what you were getting at (note, I have slightly altered the notation):
Assume x is a local minimum of f.
Define [tex]g(h) = f(x + h e_i)[/tex] considering small values of h (so that |h| < r)
Note that g(0) = f(x). So,
[tex]g(0) \leq g(h) \forall |h| < r[/tex]
That is, g has a local minimum at h = 0.
Since g is a function in one variable, we know that g'(0) = 0 since g has a local min at 0.
Then, [tex] g'(h) = \lim_{t \to 0}\frac{g(h+t) - g(h)}{t} \\<br /> g'(h) = \lim_{t\to 0} \frac{f(x+(h+t) e_i) - f(x+h e_i)}{t}[/tex]
Since we know g'(0) = 0, plugging in h = 0 we get:
[tex]0 = \lim_{t\to0}\frac{f(x + t e_i) - f(x)}{t}[/tex], which is what we wanted to show.
eh?
(p.s. Thank you so much for your helpful hints.)
