prove that the group U(n^2 -1) is not cyclic
  • Thread starter Thread starter 2e4L
    Cyclic Group
2e4L
Sorry if I formatted this thread incorrectly as its my first post ^^
For every integer n greater than 2, prove that the group U(n^2 - 1) is not cyclic.
I've done a problem proving that U(2^n) is not cyclic when n >3, but I'm failing to make a parallel.
How does one find the order of (n^2 -1)? Is this information even needed to solve this problem?
you might want to prove some easier things first:
suppose 8|k, that is:
k = 2tm, where t ≥ 3.
then φ(k) = φ(2t)φ(m), so
U(k) ≅ U(2t) x U(m).
use this to show U(k) cannot be cyclic, as it has a non-cyclic subgroup.
now, consider even n and odd n for n2-1 separately.
I have learned that property of Euler's totient function, but not the one about U(ab) = U(a) x U(b). I've come across it online, but have yet to use it in class.
Is there another method?
U(ab) isn't always isomorphic to U(a) x U(b).
for example U(4) is cyclic of order 2, but U(2) x U(2) has but a single element: (1,1).
it IS true, if a and b are co-prime.
this is actually a consequence of the chinese remainder theorem:
if gcd(m,n) = 1, then [a]mn→([a]m,[a]n) is a group isomorphism of (Zmn,+) with (Zm,+) x (Zn,+).
it's easy to check that [a]mn→([a]m,[a]n) is a ring homomorphism as well, hence Zmn and Zm x Zn have isomorphic groups of units (when...gcd(m,n) = 1. this is key).
i find it odd, that you wouldn't use this result, since it builds on the result of your previous problem.
It may be because it's still fairly early in the course. I learned the Chinese Remainder Theorem in a number theory class, but have yet to encounter it in my current one. We are going to study rings after the upcoming exam.
The previous problem was in a different chapter of the text I believe. This question is supposed to be a "review."
