Prove the existence of row-reduced matrices with restrictions
  • Thread starter Thread starter rockerman
    Existence Matrices
The discussion revolves around the existence of row-reduced matrices with specific restrictions, particularly focusing on a 2x2 matrix with complex entries where the sum of its elements equals zero. Participants explore the definitions and characteristics of row-reduced matrices as outlined in a linear algebra textbook.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants discuss the definition of row-reduced matrices and question the completeness of the original poster's list of such matrices. There is exploration of various forms of row-reduced matrices and their compliance with the given condition.
Some participants have provided guidance on identifying additional row-reduced matrices that meet the specified condition. There is an ongoing exploration of how to prove the existence of three such matrices, with various interpretations and definitions being examined.
Participants note the importance of the definition of row-reduced matrices as provided by the textbook, which may differ from common expectations. There is also mention of constraints related to the problem's requirements and the implications of the determinant in the context of the system of equations.
rockerman
Let A = [a b; c d] a 2x2 matrix with complex entries. Suppose that A is row-reduced and also that a+b+c+d =0 . Prove that there are exactly three such matrices...
so i realize that there are seven possible 2x2 matrices that are row-reduced.
[1 0; 0 1], [0 1; 1 0], [0 0; 1 0], [0 0;0 1], [1 0; 0 0], [0 1; 0 0], [0 0; 0 0]...
and the only one that satisfies the restriction is the last. What am i missing? thx
This is the problem 6 of the section 1.3 of HOFFMAN and KUNZE - Linear Algebra.
Hi rockerman! :smile:
How did you define a row-reduced matrix?
I ask this because I highly doubt that
1) [1 0; 0 1], [0 1; 1 0], [0 0; 1 0], [0 0;0 1], [1 0; 0 0], [0 1; 0 0], [0 0; 0 0] are the only row-reduced matrices. In fact, I think there are infinitely many of them.
2) I don't think [0 1; 1 0], [0 0; 1 0], [0 0;0 1] even are row-reduced.
But all of this depends on the definition you're using. So, what is it?
so..
the row reduced definition provided by the book is given as follows:
An mxn matrix R is called row-reduced if:
a) the first non-zero entry in each non-zero row of R is equal to 1;
b) each column of R which contains the leading non zero entry of some row has all its other entries 0.
This way, i think that only exists seven row-reduced matrices in R^(2x2).. but I'm not figuring out how to prove the existence of three such matrices..
What about matrices like
[tex]\left(\begin{array}{cc} 1 & a\\ 0 & 0 \end{array}\right)[/tex]
Isn't that row-reduced too?
oh, how I've missed this...
so there are many row-reduced matrices like that... but how i will find the three matrices that satisfies the condition?
Choose a special a...
the a that satisfies the condition is a= -b -c -d. So the three possible matrices are:
[tex]\left(\begin{array}{cc} 1 & a\\ 0 & 0 \end{array}\right)[/tex], [tex]\left(\begin{array}{cc} 0 & 0\\ 1 & a \end{array}\right)[/tex] and [tex]\left(\begin{array}{cc} 0 & 0\\ 0 & 0 \end{array}\right)[/tex]
is that correct?
Seems correct!
I was limiting my thinking to the most obvious cases of existence of such matrices. many thanks for the help; By now i have only one more doubt about my current exercise set. can i post on this topic?
I'll better read on the forum rules;
I don't think the rules say anything about such a things. So you can post it here if you want :smile:
oh thanx...
The problem
Consider the system of equations AX = 0 where
[tex]A = \left(\begin{array}{cc} a & b\\ c & d \end{array}\right)[/tex]
is a 2x2 matrix over the field F. Prove the following
(a) If every entry of A is 0 then every pair (x1, x2) is a solution of AX = 0;
(b) if ad-bc != 0, the system AX = 0 has only the trivial solution x1 = x2 =0;
Attempt to solution:
(a) is pretty straightforward. I just show the form of the system {0*x1 + 0*x2 = 0; 0*x1 + 0*x2 = 0
and by the real numbers properties i conclude that any (x1, x2) satisfies the equation.
(b) let me in doubt. So far in the book, the word determinant even is mentioned. So i can't use this as a reasonable argument. I claim the follow:
if ad = bc then i can write a + b = k*(d+ c). By this way the process to make a row-reduced diagonal matrix will fail, resulting in other non-zero solutions. But the problem is exactly on prove the first statement (ad = bc implies that a+ b = k*(d+c)). How can i state this in a mathematical manner?
Analysing the first question I found an inconsistency. The matrix could be, say:
[tex]\left(\begin{array}{cc} 1 & b\\ 0 & 0 \end{array}\right)[/tex]
Is that a problem? because from the point of view of matrices, these two are different.
rockerman said:
oh thanx...
The problem
Well, for (b), can't you just solve the system of equations by row reducing things? Just try to reduce the matrix and you'll see where ad-bc comes in!
Oh weird. I would have expected "row-reduced" to include that the ones are moved to the top and sorted; e.g.
[tex]\left( \begin{matrix} 1 & 0 & 0 \\ 0 & 1 & 0 \\ 0 & 0 & 0 \end{matrix} \right)[/tex]
is row reduced, but neither of the following are:
[tex]\left( \begin{matrix} 0 & 0 & 0 \\ 1 & 0 & 0 \\ 0 & 1 & 0 \end{matrix} \right)[/tex]
[tex]\left( \begin{matrix} 0 & 1 & 0 \\ 1 & 0 & 0 \\ 0 & 0 & 0 \end{matrix} \right)[/tex]
as micromass stated, it is has to do with the definition that you are using... in this case the book (HOFFMAN - Linear Algebra) states as being the rows at any order.
great tip micromass! thanx...
I don't know, but maybe i just have to look at the problem at the simplest manner possible...
the first thing that i did before was:
[tex](1) -> A = \left( \begin{matrix} 1 & b/a \\ c & d \end{matrix} \right)[/tex]
by doing so, i was stuck and nothing could be done anymore.
  • · Replies 16 ·
  • · Replies 25 ·
