Proving [a,b] and ℝ are not homeomorphic
45 replies · 9K views
davidge
I was trying to show that a closed interval ##[a,b]## and ##\mathbb{R}## cannot be homeomorphic. I would like to know whether this can actually be considered as a proof. It is the following:
- The closed interval ##[a,b]## can be written as ##[a,p] \cup [p,b]##, where ##a \leq p \leq b##.
- ##\mathbb{R}## can be written as ##(- \infty, q) \cup (s, \infty)##, where ##s < q##.
Let ##[a, b] = A## and ##[p,b] = B##.
If there is a homeomorphism ##f## from ##[a, b]## to ##\mathbb{R}##, then
- ##\mathbb{R} = f(A) \cup f(B)##
Each point on ##f(A) \cap f(B)## is the image of one, and only one, point which is in both ##A## and ##B##. Considering the extreme case, there will be only one point on ##A \cap B##, namely ##\text{{p}}##. On the other hand, ##f(A) \cap f(B)## will have more than one point (possibly infinite points) as it is the intersection of two open intervals ##f(A)## and ##f(B)## whose union is ##\mathbb{R}##.
So ##f## cannot be an injection, which contradicts ##f## being a homeomorphism.
I assume you mean to write [itex]A=[a,p][/itex]. How do you know that [itex]f(A)[/itex] and [itex]f(B)[/itex] are of the form [itex](-\infty,q)[/itex] and [itex](s,\infty)[/itex], respectively?
You are correct. I should have only said that ##\mathbb{R} = f(A) \cup f(B)##. We don't know the form of ##f(A)## nor ##f(B)##.
Okay, but then you can't conclude [itex]f(A)\cap f(B)=(s,q)[/itex].
Yes. I'm going to edit my post.
Wait, by a suitable choice of the function ##f##, ##f(A)## and ##f(B)## would have those forms, wouldn't?
You don't get to choose [itex]f[/itex]. You have to prove that no such [itex]f[/itex] is a homeomorphism.
Plase, take a look at the opening post again. I have edited it.
I think I still have the same objection. Why are [itex]f(A)[/itex] and [itex]f(B)[/itex] open intervals?
Infrared said:
I think I have the same objection still. Why are [itex]f(A)[/itex] and [itex]f(B)[/itex] open intervals?
Because ##\mathbb{R}## is open, and thus it has to be the union of two open intervals?
Having [itex]\mathbb{R}=A\cup B[/itex] doesn't mean that [itex]A[/itex] and [itex]B[/itex] are open. What if, say, [itex]A=(-\infty,0][/itex] and [itex]B=[0,\infty)[/itex]?
In this case, as ##A## is closed and ##(- \infty, 0]## is not, ##f## would not be a bijection. Similarly for ##B## and ##f(B)##.
[itex](-\infty,0][/itex] is a closed subset of [itex]\mathbb{R}[/itex].
I have to leave now, but here are a couple hints/solution sketches in case you get stuck:
Show that a continuous injection [itex]f:[a,b]\to\mathbb{R}[/itex] has to be (strictly) monotonic. Examine [itex]f(a)[/itex] to violate surjectivity.
Alternatively, recall the following form of the intermediate value theorem: If [itex]J\subset\mathbb{R}[/itex] is an interval and [itex]f:J\to\mathbb{R}[/itex] is continuous, then [itex]f(J)[/itex] is an interval. It can be used as follows: [itex]f([a,b))[/itex] must be an interval in [itex]\mathbb{R}[/itex], but it is also the punctured line [itex]\mathbb{R}\setminus\{f(b)\}[/itex] by bijectivity. Contradiction.
Thanks for the hints
Would another way be noticing that any bijection from a closed interval maps to a closed set? (While ##\mathbb{R}## is open.)
No, [itex]\mathbb{R}[/itex] is closed too, as a subspace of itself (open does not imply not closed). Also, mere bijections don't preserve openness/closedness- you're using the fact that [itex]f^{-1}[/itex] is continuous when you say that [itex]f[/itex] takes closed sets to closed sets.
If you're familiar with compactness, you could just say [itex][a,b][/itex] is compact while [itex]\mathbb{R}[/itex] isn't and this would show the stronger statement that there is no continuous surjection [itex][a,b]\to\mathbb{R}[/itex], but it's better to do things with your bare hands when learning this stuff.
WWGD said:
Hint: Heine -Borel theorem.
See my last post.
Infrared said:
See my last post.
Ah, sorry. You can then use the connectivity number: removal of anyone point will disconnect the Real line, while the same is not the case for [a,b]. Can you see that?EDIT: along the lines of post 14, consider this and the Euler number.
Yep, this is basically my second hint in post 14 (restating IVT in connectivity terms).
Yes, I find it more easy to show they are not homeomorphic by arguments of compactness. But the thing is that I want to prove it without using compactness.
How does one show this?
Sorry, I don't see.
davidge said:
Sorry, I don't see.
The intermediate value theorem tells you that [itex]f([a,b))[/itex] is an interval. Since [itex]f[/itex] is an injection, [itex]f(b)\notin f([a,b))[/itex] as otherwise we would have [itex]f(c)=f(b)[/itex] for some [itex]c\in[a,b)[/itex], contradicting injectivity. Also, for any real [itex]y\neq f(b)[/itex], there is a [itex]x\in[a,b)[/itex] with [itex]f(x)=y[/itex] by surjectivity. Hence, [itex]f([a,b))=\mathbb{R}\setminus\{f(b)\}[/itex], which is not an interval. Contradiction.
Is any step still unclear?
Edited to acknowledge.
How does one show this?Sorry, I don't see.
What happens when you remove ( one- or- more of) the endpoints of ##[a,b]##, is the resulting space connected? By contrast, what happens when you remove any point from the Real line; is the resulting space connected?
I don't know how to use the concept of connectness in this case, as the resulting space e.g. ##[a,b)## is half-open, and by the definition of connectness the space must be open.
Yes, but we are considering connectedness, not openness; the space remains connected.
What definition of connectedness are you thinking of? The one I know states that a space is disconnected if it can be expressed as the union of two open spaces, such that their intersection is empty.
davidge said:
What definition of connectedness are you thinking of? The one I know states that a space is connected if it can be expressed as the union of two open spaces, such that their intersection is empty.
Well, yes, the definition I know of for connectedness is a "negative definition" , in that a space is connected if there exists no disconnection of the space. But tyou need to tighten your definitoon, otherwise, ## (0,1) \cup (2,3) ## is connected.
Oops, I edited my last post. I meant "disconnected" instead of "connected".
