Proving associativity of the biconditional
  • Thread starter Thread starter tgt
    Proof
29 replies · 6K views
tgt
GIve a formal proof or derivation of:
(a iff (b iff c)) iff ((a iff b) iff c))
I've tried it for a long time. Idea is to assume (a iff (b iff c)) then get ((a iff b) iff c)) and then vice versa. BUt no matter how I try, I always get some if conditions istead of the iff.
Well, the most brain-dead way is to write down a truth table, and invoke the fact that a proposition is a tautology if and only if all of the entries in its truth table are "true".
The aim was to use deduction rules to prove it. In other words to deduce it all. That is the method I'm trying to use to prove it.
Just thinking about it, deductions are always tautologies. i.e if one is asked to deduce B from A, A and B are the same statement but in different form.
Not so. The simplest counterexample is probably to let A be "contradiction" and to let B be "tautology". You can deduce B from A, but I doubt you could argue that they are "the same statement but in a different form".
(I chose contradiction and tautology because they appear in the two trivial proofs: you can deduce anything from a contradiction, and from anything you can deduce a tautology)
How about the solution to the OP? It seems impossible but it is so obvious.
What do you mean by being able to deduce anything from a contradiction?
Is that this: Suppose we have a contradiction then we add the negation of the thing we are trying to deduce at the beginning of the contradiction. Then the end result is that we have deduced the thing we are trying to prove.
i.e Assume
John is dead,
Tim has a bread,
Tim does not have a bread
Contradiction!
Hence John is not dead.
But we could just as easily prove John is dead by reversing things.
That is exactly correct. Such is the nature of contradictions.
Just use the definition:
A=>B is not(A) OR B
Plug things in and reduce both sides to some canonical form.
What about the example,
Phil is gone,
John is dead,
Tim has a bread,
Contradiction!
Now we could choose between concluding
John is not dead and Phil is not gone?
Any choice would be okay?What about the example,
John is dead,
Suppose there are finitely many primes,
Conclude a contradiction that the product of those primes plus 1 cannot be a prime nor not a prime.
Now we can either conclude John is not dead or There are infinitely many primes. EIther choice being correct?What about the example,
pi is an irrational number
Now we can either conclude pi is rational or There are infinitely many primes. EIther choice being correct?
A=>B is not(A) OR B
I've worked out the problem using the technique of deduction.
Phil is gone,
John is dead,
Tim has a bread,
Contradiction!
This seems to me to be nonsense, not a contradiction. Presumably, the way this is laid out, the first three statements are the hypothesis, and the fourth is the conclusion. Because Phil being gone and John being dead have nothing to do with Tim having bread, it seems to me that this can be reduced to
Tim has bread ==> Tim doesn't have bread
This is not a contradiction. If Tim has bread, then it is not true that he doesn't have bread, so the first statement does not imply the second. If Tim indeed doesn't have bread, then the first statement isn't true, so any statement at all could be appear as the conclusion, and the implication would be true, but meaningless.
BTW, in English, we don't say someone has "a bread": we say someone has bread or has a loaf of bread.
You are misunderstood. All 4 statements are intended to be the hypothesis which we arrive at a contradiction. The conclusion is that one of the hypothesis was wrong.
Maybe I misunderstood, but I wasn't misunderstood, since you apparently understood what I was saying.
It wasn't clear to me which statements were the hypothesis, and which were the conclusion. Going back to your syllogism, let's throw out the statements about Phil and John, since they don't have anything to do with anything. That leaves us with a hypothesis of (Tim has bread) AND (Tim does not have bread). This hypothesis can never be true, so you could have any conclusion, and overall the implication would be true.
For any implication, p ==> q, the implication will be true or valid under three circumstances, and false or invalid under one circumstance. The three true circumstances are:
1. p is true and q is true.
2. p is false and q is true.
3. p is false and q is false.
The invalid circumstance is:
4. p is true and q is false.
Depending on what you have for the conclusion, your syllogism of Tim having and not having bread falls into the 2nd or 3rd category.
tgt: you seem to be confusing this example of a vacuous proof with proof by contradiction.
Here are three valid arguments:
Tim has a bread.
Tim does not have a bread.
Therefore, John is dead
Tim has a bread.
Therefore, John is alive.
Phil is gone implies Tim has a bread.
Phil is gone imples Tim does not have a bread.
Therefore, Phil is not gone.
The first two are an example of "contradiction implies anything". The third is an example of proof by contradiction.
Well, I understood that you misunderstood which seems valid.
I do acknowledge that my presentation of arguments was not clear.
Wouldn't your proof by contradiction need the extra assumption to get the contradiction. So it would be better if it was:
1. Phil is gone
2. Phil is gone implies Tim has a bread.
3. Phil is gone imples Tim does not have a bread.
Where 1,2 and 3 are assumptions.
1. Phil is gone
Heavens no! Those three statements are a contradiction!
We are trying to deduce a contradiction which is what we get after combining those three statements.
To give more detail it's
If:
Phil is gone
Then:
Tim has a bread
We get a contradiction.
Conclusion:
One or more of our assumptions was wrong (or is it only one assumption was wrong?)
We say that Phil is not gone.
But couldn't we conclude that the statement 'Phil is gone implies Tim has a bread' is incorrect hence the reverse of that statement is true instead?
With regards to the OP. I realized that I've made a mistake. The technique is to use natural deduction to prove the statement.
http://www.ags.uni-sb.de/~chris/papers/2002-pisa.pdf
If:
Phil is gone
Then:
Tim has a bread
Conclusion:
But look at your argument form:
{ phil is gone and (phil is gone implies tim has a bread) and (phil is gone implies tim does not have a bread) } implies contradiction
Therefore, not { phil is gone and (phil is gone implies tim has a bread) and (phil is gone implies tim does not have a bread) }
That's exactly the form I'm describing:
P implies contradiction
Therefore, not P
What would not { phil is gone and (phil is gone implies tim has a bread) and (phil is gone implies tim does not have a bread) } be?
Would it be one of { phil is not gone or not(phil is gone implies tim has a bread) or not(phil is gone implies tim does not have a bread) }?
So we have 3 choices to choose from?
Your way of stating things "P implies contradiction Therefore, not P" is a bit too broad. Often we like to conclude an assumption in P which is wrong which is also the thing we are trying to prove.
Right; DeMorgan's laws: not(P and Q and R) = not P or not Q or not R.
Sure, but that's the basic building block. e.g. we could proceed as:
P
(P and Q) implies contradiction
Therefore not (P and Q)
Therefore not P or not Q
Therefore P implies not Q
Therefore not Q
(Of course, the actual chain of logic would depend both on which set of rules you are using, and the particular route you decided to use)
I suppose if you wanted to keep explicit track of when you're just using the logical connective and when you're talking about the existence of a proof, you could argue something like:
([itex]\vdash[/itex] is the symbol that means "there is a proof that starts with the left hand side and concludes with the right hand side")
([itex]\bot[/itex] is a symbol denoting a contradiction)
We have a metalogical theorem that
[itex]P, Q \vdash R[/itex] if and only if [itex]P \vdash Q \to R[/itex]​
You could organize your proof by contradiction as
First, prove [itex]P,Q \vdash \bot[/itex]
Then invoke the theorem to conclude [itex]P \vdash Q \to \bot[/itex]
And apply the law of noncontradiction to get [itex]P \vdash \neg Q[/itex]
Just say in a maths proof, a contradiction is reached. Can we then immediately conclude anything? For example the sky is green?
If a contradiction is reached in a mathematics-style proof, it usually means that the assumption that the hypothesis is true must be an incorrect assumption.
For example, if I want to prove that x = 1 implies that x2 - 1 = 0, I can do this by assuming that x = 1 and the opposite of the conclusion; i.e., that x2 - 1 [itex]\neq[/itex] 0.
I can square both sides of the equation x = 1 to get x2 = 1. I can then subtract 1 from both sides of the latter equation to get x2 - 1 = 0.
The last equation contradicts the assumption that x2 - 1 [itex]\neq[/itex] 0, so that assumption must be faulty, which leads us to conclude that x2 - 1 = 0.
Yes. That's why inconsistency is very bad in a mathematical theory (or any other kind of theory).
But in everyday examples, one never proves a contradiction -- one proves that some hypothesis implies a contradiction.
After that we then conclude that the initial hypothesis must be incorrect. However what is interesting is that if there are two or more assumptions then only one is false. And anyone can be picked. In that case, do we pick the assumption that we wanted to be false at the start to be false?
No, it only disproves their conjunction. If you want to prove something about them individually, you need to do something else.
So when using proof by contradiction to prove a statement, we better make sure the reverse of that statement is the only assumption in the proof (containing a contradiction)?
