Proving Convergence of a Sequence with a Given Upper Bound
16 replies · 3K views · last reply
gtfitzpatrick
Proove rigorously that if (a[tex]_{n}[/tex] is a real convergent sequence with lim[tex]_{n\rightarrow \infty}[/tex] a[tex]_{n}[/tex] = a and for each n=[tex]\in[/tex] N, a[tex]_{n}[/tex] < 6, then a [tex]\leq[/tex] 6
Let [tex]\epsilon[/tex] > 0 we need to find n[tex]_{0}[/tex] [tex]\in[/tex] N such that
[tex]\left\|[/tex] a[tex]_{n}[/tex] - a[tex]\left\|[/tex] < [tex]\epsilon[/tex] [tex]\forall[/tex] n [tex]\geq[/tex] n [tex]_{0}[/tex], n[tex]_{0}[/tex] [tex]\in[/tex] N
but a[tex]_{n}[/tex] < 6
so
[tex]\left\|[/tex] 6 - a[tex]\left\|[/tex] < [tex]\epsilon[/tex]
then
a < 6 - [tex]\epsilon[/tex] and [tex]\epsilon[/tex] > 0
so a [tex]\leq[/tex] 6
i think I've done this right, just by using the definition of a limit. Could anyone tell me if this is looking ok?
(Also i can't seem to get the sub script working, it always makes them go up instead of down, any ideas anyone?)
Thanks a million
No, you're off track. You know that the sequence converges, so no matter what [tex]\epsilon[/tex] is given you can make
[tex] |a_n - a| < \epsilon[/tex]
if n is large enough.
But this:
so
doesn't follow.
Try assuming [tex]a > 6[/tex] and see if you can reach some contradiction. (Hint: if [tex]a > 6[/tex] then [tex]a - 6 > 0[/tex].)
thanks for getting back to me.
ok let me see if i have this right now.
first since the sequence is convergent [tex]\epsilon[/tex] > 0. then set a > 6 so
Since the sequence is convergent a[tex]_{}n[/tex] - a < [tex]\epsilon[/tex] or a < a[tex]_{}n[/tex] - [tex]\epsilon[/tex] but if a > 6 then 6 - [tex]\epsilon[/tex] > a > 6 which can't be true so a muxt be < or = 6
Not quite . My point was that since [tex]a - 6 >0[/tex] it would be a possibility for choice as [tex]\epsilon[/tex]
thanks for all the help,
do you mean a - 6 > 0 and an -a < [tex]\epsilon[/tex] then an - a < a - 6 ?
I must be still lookin at this wrong, can't seem to figure it out
Think of it intuitively first.
If [tex]a_n < 6[/tex] for all n, and you want to prove that [tex]a \le 6[/tex], then assume the opposite. Assume that [tex]a > 6[/tex]. But since [tex]a_n \rightarrow a[/tex] then that means we can make [tex]a_n[/tex] as close to a as we want, provided that n is taken large enough, right?
Do you see how if a > 6 then there is no way we can possibly make [tex]a_n[/tex] as close to a as we want, no matter how large n is? Because for all n, [tex]a_n < 6[/tex] ?
Make this into a rigorous argument now.
thanks a mill for replying
I can see that if an < 6 and a > 6 but an [tex]\rightarrow[/tex] a so they can't converge as they are both on opposite sides of 6 so to speak, but I am just not sure how to go about prooving this rigourously
Assume a > 6. Since [tex]a_n < 6 < a[/tex] for all n, we have [tex]a - a_n > 0[/tex]. So [tex]|a_n - a| = a - a_n[/tex].
Now, we know that for every positive [tex]\epsilon[/tex] , [tex]a - a_n < \epsilon[/tex] provided that n is large enough. If a > 6 then a - 6 > 0, and so we can take [tex]\epsilon = a - 6[/tex]. Try that out and see what happens.
the first part of this is grand. the second part, I am not following are you getting it from the def of a limit [tex]\left|[/tex]an-a [tex]\left|[/tex] < [tex]\epsilon[/tex]
In the part you quoted, I'm just making it clear that |a_n - a| = a - a_n.
I'd rather get rid of the absolute value bars.
The rest of my post uses the definition of a limit.
JG89 said:
|a_n - a| = a - a_n.
sorryi'm not getting this, is this just because a>6>a_n
Yes. You know that |a_n - a| = |a - a_n|, right? but a - a_n > 0 anyway since a > a_n, so we can just drop the absolute value bars and write a - a_n
Damn this just isn't working for me- [tex]\epsilon = a- 6[/tex] but [tex]\epsilon>0[/tex] so a-6> 0 or a>6 which is what I'm trying to disprove!
a-an < [tex]\epsilon[/tex] and a - 6 = [tex]\epsilon[/tex]
then a-an < a - 6
which works out to an < 6 which is true?
then a-an < a - 6
[tex] a - a_n < a - 6[/tex]
leads to
[tex] a_n < 6[/tex]?
Check your signs again.
damn it, sorry bout that. thanks a million for the help
