Proving Determinant of Matrix Unchanged by Adding Columns
The discussion centers on proving that the determinant of a matrix remains unchanged when a multiple of one column is added to another. It highlights that the determinant is linear in each variable, illustrated through examples with 2x2 matrices where linearly dependent columns yield a determinant of zero. The geometric interpretation compares this to shearing a parallelogram, where the area remains constant if the height is unchanged. Additionally, the discussion references the identity matrix and a specific matrix transformation that maintains the determinant's value. Overall, the key takeaway is that adding a multiple of one column to another does not alter the determinant of the matrix.
Unusualskill
Any1 can explain in an easy way?I know is something to do with the facts that row operations do not change the determinant of a matrix and also determinant of A=determinant of A transpose.But just dk how to prove in full sentence. Appreciate any1 help.
I'll explain by example. Let's say u is some vector in R^2 and v is a multiple of it. Then suppose we form a 2 by 2 matrix (u, v) by taking u as the first column and v as the second. The determinant is 0 because the columns are linearly dependent. We can write it as
det(u, v) = 0 = det(v, u).
Now, suppose we have a matrix (v, w). We want to see what happens when we add a multiple of v to another column, like this: (v, w+u). We can use the fact that the determinant is linear in each variable.
det(v, w + u) = det(v, w) + det(v, u) = det(v, w) + 0 = det(v,w).
The same thing will happen if we look at n by n matrices because you're adding something that's going to be linearly dependent.
Geometrically, this is like the geometry theorem that you can shear a parallelogram without changing its area. It's always base times height, so if you don't change the height, it stays the same. Try to see how that relates to my argument by drawing the parallelogram spanned by some vectors v and w, then the one spanned by v and w+u. Remember that the meaning of the determinant is that it is the signed area of this parallelogram (or volume in higher dimensions).
Suppose ##M## is any ##n \times n## matrix, and ##1 \leq i,j \leq n## with ##i \neq j##.
If ##I## is the ##n \times n## identity matrix and ##J## is the ##n \times n## matrix with a ##1## in row ##i##, column ##j##, and ##0## everywhere else, then define ##A = I + J##. It's easy to check that ##AM## is the matrix formed by replacing the ##i##'th row of ##M## with the sum of the ##i##'th and ##j##'th rows. Note that ##A## is either upper triangular (if ##i > j##) or lower triangular (if ##i < j##), so its determinant is the product of its diagonal elements, which are all ##1##. Therefore ##\det(A) = 1##. Consequently, ##\det(AM) = \det(A)\det(M) = \det(M)##.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 34 ·
