Proving functions are linearly dependent
  • Context: Undergrad
  • Thread starter Thread starter brotherbobby
    Functions Linearly
5 replies · 2K views
brotherbobby
TL;DR
We have set of functions ##\varphi (t)## continuous in the interval ##[a,b]##. The set is a linear (vector) space with the usual definitions of addition and multiplication by real numbers. We denote this space by ##C[a,b]##.
Statement of the problem : Prove that the following set of functions are linearly independent in the space ##C[a,b]## mentioned above : ##\varphi_1(t) = \sin^2 t, \varphi_2(t) = \cos^2 t, \varphi_3(t) = t, \varphi_4(t) = 3 \; \text{and} \; \varphi_1(t) = e^t##
We can make the first three functions add up to zero in the following way : ##\sin^2 t+\cos^2 t-\frac{1}{3}\times 3 = \varphi_1(t) + \varphi_2(t) - \frac{1}{3} \varphi_3(t) = 0##.
However, look at ##\varphi_4(t) = t## and ##\varphi_5(t) = e^t##. How does one combine the two to add up to zero? I can't see a way out.
Any help would be appreciated.
What about using the differentiability of these functions?
brotherbobby said:
Summary:: We have set of functions ##\varphi (t)## continuous in the interval ##[a,b]##. The set is a linear (vector) space with the usual definitions of addition and multiplication by real numbers. We denote this space by ##C[a,b]##.
##\text{Statement of the problem :}## Prove that the following set of functions are linearly independent in the space ##C[a,b]## mentioned above : ##\varphi_1(t) = \sin^2 t, \varphi_2(t) = \cos^2 t, \varphi_3(t) = t, \varphi_4(t) = 3 \; \text{and} \; \varphi_1(t) = e^t##
You say you want to show linear independence, but you gave a non trivial linear combination?
If ##\vec{u},\vec{v}## are linearly dependent, then ##\{\,\vec{u},\vec{v},\vec{w}\,\}## are automatically linearly dependent, too.
If ##\vec{u},\vec{v}## are linearly dependent, then ##\{\,\vec{u},\vec{v},\vec{w}\,\}## are automatically, too, linearly dependent.
I assumed the question is to investigate the linear indepence of these functions.
Many thanks. Sorry I forgot this is a theorem. "Given any two linearly dependent functions, any larger set of vectors involving the two is also linearly dependent".
Many thanks and apologies.
You don't need to cite any theorem: ##\sin^2(t)+\cos^2(t)+0\cdot t-\frac{1}{3}3+0\cdot e^t## is a nontrivial linear combination that is zero (and this example should make it clear why that theorem is true).
