Proving I1*I2 is an Ideal in Commutative Ring R
  • Context: Graduate
  • Thread starter Thread starter Chen
    Product
The discussion centers on the proof of whether the product of two ideals, I1 and I2, in a commutative ring R is itself an ideal. Participants explore definitions, provide counterexamples, and seek clarification on the properties of ideal products.
  • Chen defines the product of ideals as {x*y | x in I1, y in I2} and expresses difficulty in proving it is a group under addition.
  • Some participants question the definition provided by Chen, suggesting it may not align with standard definitions of ideal products.
  • A participant mentions the need to prove that the group defined by Chen is an ideal, indicating a potential misunderstanding of the concepts involved.
  • Another participant seeks a counterexample to demonstrate whether the product as defined by Chen is an ideal, indicating uncertainty about its validity.
  • One participant suggests that the product of ideals is actually generated by the set of products {fg | f in I, g in J}, rather than being equal to it.
  • Another participant asserts that the product of ideals is tautologically an ideal, emphasizing that it is defined as the ideal generated by those products or sums of them.
  • A further contribution provides a definition of the product of ideals that includes sums of products, suggesting a more comprehensive understanding of the concept.
Participants express disagreement regarding the definition of the product of ideals and whether the initial definition provided by Chen is correct. Multiple competing views on the nature of ideal products remain unresolved.
There are limitations in the definitions provided, and participants have not reached a consensus on the correct characterization of the product of ideals. The discussion reflects varying interpretations and assumptions about the properties of ideals in commutative rings.
Chen
Given a commutative ring R with a unit, how do you prove that the product of two ideals, I1 and I2, is also an ideal?
The product of course is defined to be {x*y | x in I1, y in I2}, where * is the multiplication in the ring R.
I'm having trouble proving that I1*I2 is a group under addition.
Thanks,
Chen
Are you sure?
http://planetmath.org/encyclopedia/ProductOfIdeals.html
Well I can see this definition doesn't match mine, but at any rate - I was asked to prove that this group:
is an ideal.
I'm working on the similar problem right now, and I was going through many threads in this forum and couldn't find the answer whether the product as Chen defined it is an ideal. I wanted to find the counterexample that {x*y | x in I1, y in I2} is an ideal, but was not able to come up with anything. So, does anybody have any ideas of how to do it, or can you at list give me a hint whether or not it is an ideal? Thanks!
Chen said:
Well I can see this definition doesn't match mine, but at any rate - I was asked to prove that [EDIT: I changed Chen's notation--- CH]
<br /> I \, J = \{ fg | f \in I, g \in J \}<br />
is an ideal.
Is it possible that you are confusing an abelian subgroup with a subring with an ideal? A good short textbook which should help is Herstein, Abstract Algebra. See the excellent and very readable textbook by Cox, Little, and OShea, Ideals, Varieties, and Algorithms, for much more about such constructions as IJ, \, I \cap J, \, I+J, \, I:J, \, \sqrt{I}.
I suspect that the question had meant that IJ is generated by the set {fg : f in I, g in J}, and not equal to it. Occasionally this is expressed by writing IJ = <fg : f in I, g in J>.
Ditto morphism (this point and others are well explained in IVA).
your definition is wrong. the product of ideals is tautologically an ideal, as it is defined as the ideal generated by those products, or equivalently as all sums of them.
Hi,
I saw many people have given a wrong definition for the product of ideals. The following is the correct definition as appeared in mathematical text:
I*J = {i[1]*j[1]+i[2]*j[2]+...+i[n]*j[n]:i[n] in I and j[n] in J where n is finite}
