Proving Isolated Photon Doesn't Split into Two Photons
The discussion centers on the challenge of proving that an isolated photon cannot split into two photons traveling in different directions. The initial argument highlights the relationship between energy and momentum, emphasizing that if a photon were to split, it would violate momentum conservation unless the resulting photons had mass or moved in opposite directions. Participants reference equations related to energy and momentum conservation, specifically focusing on the conservation of 4-momentum. The conversation also touches on the implications of these equations in the context of photon behavior. Ultimately, the discussion aims to clarify the fundamental principles governing photon interactions and conservation laws.
Xamfy19
Here is the question I had trouble with it:
How to prove that an isolated photon cannot split into two photons going in direction other than the original direction.
I thought photon doesn't have mass, then
energy = momentum.
from momentum conservation law. If photon split into two part and travel in different direction, then it must have different mass (or at opposite direction).
That's all I have for the time being.
Thanks for the help.
p^{\mu}=p_{1}^{\mu}+p_{2}^{\mu} (1)
Workin' in Heaviside-Lorentz units,
\omega=\omega_{1}+\omega_{2} (2)
\vec{p}=\vec{p}_{1}+\vec{p}_{2} (3)
Square (2) & (3) and use \omega=|\vec{p}| (which is valid for all 3 photons).
Denote the angle between the momenta of outgoing photons by \theta
Daniel.
Great, but what are the p^u, w and p?
I guess
w = w1 + w2 is the energy conservation
p = p1 + p2 is the momentum conservation, and what is
the first equation ?
thanks
Conservation of 4-momentum,what else...?That's where the other 2 eqns come from.
Daniel.
thanks, Daniel
