Proving non homeomorphism between a closed interval & ##\mathbb{R}##
45 replies · 8K views
I think I have found a problem. Consider ##(0, 2 \pi]## and ##[-1,1]##, and the function ##\text{Sin(x)}##. There seems to be a surjection from ##(0, 2 \pi]## to ##[-1,1]##.
- By compactness theorem, this can't be true, since the former is not compact while the latter is.
- By connectedness, this is true, since both are connected.
How do we solve this problem?
Krylov said:
What is the "compactness theorem"? What does it say?
Well, a half-open space requires infinite unions of closed spaces, approaching its open end element, but never reaching it. So isn't it not compact?
I think the theorem you're talking about is that the image of a compact space under a continuous map is compact. This says nothing about when the domain is not compact. It is of course possible for a non-compact space to map surjectively onto a compact one. Take the constant function [itex](0,1)\to\{1\}[/itex] for a simpler example.
Yes
Why not? Can you point out where I'm wrong in the following? Suppose ##X## is a non compact space and suppose we have a surjection ##f## from ##X## to another space ##Y##. Then
$$X = \bigcup_{i \in I} U_i = \bigcup_{i \in F \subset I} U_i \Longleftrightarrow F = I$$
Also, ##Y = f(X)##. That is, ##Y## is the image of ##X## under ##f##. But $$ f(X) = f \bigg(\bigcup_{i \in I} U_i \bigg) = f \bigg(\bigcup_{i \in F \subset I} U_i \bigg)$$ with ##F = I##, which means ##Y## is also not compact.
davidge said:
Yes
Like Infrared pointed out: what if ##Y##={##pt##}, a singleton? Or consider ##[-1,1)## under ##f(x)=x^2 ##.
Oh, I see. So what can we conclude from all this? Connectedness is a stronger condition than compactness when determining whether or not two spaces are homeomorphic?
No, neither compactness nor connectedness implies the other. [itex](0,1)[/itex] is connected but not compact. [itex]\{0,1\}[/itex] is compact but not connected.
Edit: Also, sorry but I can't understand your attempted proof that the image of a non-compact space is non-compact.
I think, if I( understood you correctly) that you are trying to argue ## (A \rightarrow B) \rightarrow (\neg A \rightarrow \neg B )## e.g., if compact is sent to compact then non-compact is mapped into non-compact, through continuous functions.
I see
Suppose there is a surjection ##f## from a non compact space ##X## to another space ##Y##. As ##f## is a surjection, each ##y \in Y## will be the image of at least one ##x \in X##. So we can write ##Y## as the image of ##X## under ##f##, can't we? If so, it follows that ##Y## is also not compact, by the arguments shown in my post #34.
Excuse me. I was actually trying to ask whether we should test for connectedness or compactness when we want to know whether two spaces are homeomorphic.
davidge said:
I see
Ah, sorry. I can't see a general argument to be made, I just think it is more of a case-by-case basis.
I really don't understand this argument at all, so I'll just guess at where you're going wrong. Writing a space as an infinite union of open sets does not make a space non-compact. Not being compact would only follow if this open cover had no finite sub-cover.
Yes, but in most cases, a open cover doesn't have a finite sub-cover only when there are infinite elements in the index set, i.e. when a infinite number of unions is needed to cover the space.
Oh, ok
davidge said:
Yes, but in most cases, an open cover doesn't have a finite sub-cover only when there are infinite elements in the index set, i.e. when a infinite number of unions is needed to cover the space.
I don't know what you mean by 'most' here. You're interested in the case that the image is compact, which means you can find a finite sub-cover..
In any event, this thread has drifted from the topic question. I'd suggest making a new thread.
Ok. Thanks.
