Proving Real Numbers Satisfy Inequality
10 replies · 3K views · last reply
murshid_islam
the problem statement is:
if a,b,c are real numbers such that [tex]\frac{1}{a+1} + \frac{1}{b+1} + \frac{1}{c+1} = 2[/tex]
we have to prove that:
[tex]\frac{1}{4a+1} + \frac{1}{4b+1} + \frac{1}{4c+1} \geq 1[/tex]
thanks in advance.
Well I thought id at least prove a general class of the solutions, where a=b=c, but it turns out that the only solution is a=b=c=0.5. It is the only solution where the 2nd equtation is exactly 1. The others must be more.
I tried another case, where 2 solutions (a and b) are equal, and it shows a=1/(2c+1). That might help, perhaps we could prove every case to be true.
Condition:
[tex]\frac{1}{a+1}+\frac{1}{b+1}+\frac{1}{c+1}=1-\frac{a}{a+1}+1-\frac{b}{b+1}+1-\frac{c}{c+1}=2[/tex]
Hence,the condition is equivalent with:
[tex]\frac{a}{a+1}+\frac{b}{b+1}+\frac{c}{c+1}=1[/tex]
Inequality:
By similar simple algebra the inequality can be rewritten as follows:
[tex]\frac{4a}{4a+1}+\frac{4b}{4b+1}+\frac{4c}{4c+1}\leq 2[/tex]
Now,let's consider the difference "Inequality-Condition":
[tex]\left(\frac{4a}{4a+1}-\frac{a}{a+1}\right)+\left(\frac{4b}{4b+1}-\frac{b}{b+1}\right)+\left(\frac{4c}{4c+1}-\frac{b}{b+1}\right)\leq 1[/tex]
Every expression within brackets is of form [itex]\frac{4x}{4x+1}-\frac{x}{x+1}[/itex].
[tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}?\rightarrow 4x^2-4x+1<0\rightarrow 4\left(x-\frac{1}{2}\right)^2<0\longrightarrow Contradiction![/tex]
QED
EDIT:BTW,this cute little problem was misplaced in dumb brainteasers section.
Elementar proof presented here is understandable even to 6th graders.:smile:
how do you get a contradiction here? i get:
[tex]\frac{4x}{4x+1} - \frac{x}{x+1} > \frac{1}{3}[/tex]
[tex]\frac{3x}{(4x+1)(x+1)} > \frac{1}{3}[/tex]
[tex]\frac{9x}{(4x+1)(x+1)} > 1[/tex]
[tex]\frac{9x}{(4x+1)(x+1)} - 1 > 0[/tex]
[tex]\frac{9x - 4x^2 - 5x - 1}{(4x+1)(x+1)} > 0[/tex]
[tex]\frac{4x^2 - 4x + 1}{(4x+1)(x+1)} < 0[/tex]
[tex]\frac{(2x-1)^2}{(4x+1)(x+1)} < 0[/tex]
[tex](4x+1)(x+1) < 0[/tex]
[tex]x \in \left(-\frac{1}{4}, -1\right)[/tex]
so where is the contradiction?
Ahh here's your problem murshid_islam, you know when you copyed this problem over from the brain teasers section? https://www.physicsforums.com/showthread.php?t=131366
Take a look at the original question, a b and c have to be positive. All the solutions to that quadratic inequality are negative, and therefore we reach a contradiction.
thanks Gib Z. but still, the contradiction tehno got is wrong, isn't it?
Why is the contradiction wrong? The inequaility has only negative solutions, which is contradictory from the original assumption of positive solutions.
tehno said:
[tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}?\rightarrow 4x^2-4x+1<0[/tex]
how do you get from [tex]\frac{4x}{4x+1}-\frac{x}{x+1}>\frac{1}{3}[/tex] to [tex]4x^2-4x+1<0[/tex]
thats what i said was wrong?
Well I've tried for 30 mins now, i can't see how he got that either. Help tehno!
From here, x is positive, and so the denominator is always positive. So, for the inequality to hold, we require [itex]4x^2 - 4x + 1<0[/itex]. From here, the contradiction is obtained as in tehno's post.
