Proving the Finite Binomial Series for k Non-Negative Integer
The discussion revolves around proving that the Binomial Series is finite when k is a non-negative integer. Participants explore various methods and reasoning to understand the finiteness of the series expansion of (1+x)^k.
  • One participant questions how to prove that the Binomial Series is not infinite for non-negative integers, seeking examples for clarity.
  • Another participant asks if the series expansion of (1+x)^k is the focus and questions the assumption that it could be infinite.
  • It is noted that for non-negative integers, the binomial series eventually yields 0, leading to a finite number of terms.
  • A suggestion is made that the finite degree of the polynomial should suffice as proof of finiteness.
  • One participant mentions the convergence of power series and provides an example of a related series that converges under certain conditions.
  • Another participant emphasizes that when k is a positive integer, the expansion indeed has a finite number of terms.
  • A mathematical induction approach is proposed to demonstrate the finiteness of the series.
  • Different methods are presented, including the polynomial nature of (1+x)^k and the behavior of coefficients in the series expansion when k is a non-negative integer.
  • A compact representation of the binomial expansion is also provided, linking it to combinatorial interpretations.
Participants express varying degrees of understanding regarding the proof of finiteness, with some agreeing that the polynomial nature of the expansion leads to a finite series, while others seek further clarification on the underlying principles.
Some participants reference the need for a more rigorous proof or examples, indicating that assumptions about the nature of the series and its coefficients may not be universally understood.
Adrenaline101
TL;DR
What is the method to prove that a binomial series is not infinite when k is a non-negative integer.
Hello,
I was wondering how to prove that the Binomial Series is not infinite when k is a non-negative integer. I really don't understand how we can prove this. Do you have any examples that can show that there is a finite number when k is a non-negative integer?
Thank you!
Do you mean the series expansion of ##(1+x)^k##? Why should it be infinite?
Yes, I mean that expansion. I was wondering how to prove that this series expansion is finite when k i a non-negative integer, because eventually, if the value of k is non-negative, this binomial series's values will eventually be 0.
I just cannot find a written proof that allows me to understand why this is happening.
Shouldn't the fact that it is a finite degree polynomial be enough proof?
Any real analysis textbook should cover the convergence of power series. In general, a power series has a radius of convergence: e.g. for the binomial expansion:
$$(1 - x)^{-1} = 1 + x + x^2 + x^3 \dots$$ converges for ##|x| < 1## and diverges otherwise.
Adrenaline101 said:
Summary:: What is the method to prove that a binomial series is not infinite when k is a non-negative integer.
Hello,
Thank you!
You mean ##k## is a negative integer, right? When ##k## is a positive integer, the expansion has a finite number of terms.
Oh I see... Sorry, I was stuck on a particular idea, which is more simple in reality.
Thank you!
Let ##n ## be a non-negative integer. If ##n=0## then for ## a \neq 0, a^n=1##, If not, :
## (1 +x )^n = (1+x)(1+x)...(1+x) ## (n times) . The expression consists of a total of n expressions,each with two terms. If you want more rigor, do induction on n. If the expression ##(1+x(^k## is finite, so is ##(1+x)^{k+1} =(1+x)^k (1+x)## . If not, consider that the expanded expression consists of all monomials ## a_n x^n ## given by ## \Sigma_{i=0}^n nCi x^i ##, where nCi is "n Choose i" . This is a finite sum with (n+1) terms.
There's various way to do it:
(1) [itex](1 + x)^k[/itex] is a product of [itex]k[/itex] polynomials of degree 1, and is therefore a polynomial of degree [itex]k[/itex].
(2) We have [tex](1 + x)^\alpha = \sum_{n=0}^\infty a_n x^n[/tex] where [tex]a_{n+1} = \frac{(\alpha - n)}{n+1}a_{n}[/tex] with [itex]a_0 = 1[/itex]. If [itex]\alpha[/itex] is a non-negative integer then [tex]a_{\alpha + 1} = \frac{(\alpha - \alpha)}{\alpha + 1}a_\alpha = 0[/tex] and thus [itex]a_n = 0[/itex] for all [itex]n > \alpha[/itex].
A compact way: [itex] 2^{n}=(1+1)^{n}=\int_{k=0}^{n}\begin{pmatrix}<br /> k\\<br /> n\\<br /> \end{pmatrix}1^{k}\cdot 1^{n-k}=\int_{k=0}^{n}\begin{pmatrix}<br /> k\\<br /> n\\<br /> \end{pmatrix}[/itex]
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 23 ·
