Proving the Finite Binomial Series for k Non-Negative Integer
9 replies · 2K views
Adrenaline101
TL;DR
What is the method to prove that a binomial series is not infinite when k is a non-negative integer.
Hello,
I was wondering how to prove that the Binomial Series is not infinite when k is a non-negative integer. I really don't understand how we can prove this. Do you have any examples that can show that there is a finite number when k is a non-negative integer?
Thank you!
Gaussian97 said:
Do you mean the series expansion of ##(1+x)^k##? Why should it be infinite?
Yes, I mean that expansion. I was wondering how to prove that this series expansion is finite when k i a non-negative integer, because eventually, if the value of k is non-negative, this binomial series's values will eventually be 0.
I just cannot find a written proof that allows me to understand why this is happening.
Any real analysis textbook should cover the convergence of power series. In general, a power series has a radius of convergence: e.g. for the binomial expansion:
$$(1 - x)^{-1} = 1 + x + x^2 + x^3 \dots$$ converges for ##|x| < 1## and diverges otherwise.
Adrenaline101 said:
Summary:: What is the method to prove that a binomial series is not infinite when k is a non-negative integer.
Hello,
Thank you!
You mean ##k## is a negative integer, right? When ##k## is a positive integer, the expansion has a finite number of terms.
Oh I see... Sorry, I was stuck on a particular idea, which is more simple in reality.
Thank you!
Let ##n ## be a non-negative integer. If ##n=0## then for ## a \neq 0, a^n=1##, If not, :
## (1 +x )^n = (1+x)(1+x)...(1+x) ## (n times) . The expression consists of a total of n expressions,each with two terms. If you want more rigor, do induction on n. If the expression ##(1+x(^k## is finite, so is ##(1+x)^{k+1} =(1+x)^k (1+x)## . If not, consider that the expanded expression consists of all monomials ## a_n x^n ## given by ## \Sigma_{i=0}^n nCi x^i ##, where nCi is "n Choose i" . This is a finite sum with (n+1) terms.
There's various way to do it:
(1) [itex](1 + x)^k[/itex] is a product of [itex]k[/itex] polynomials of degree 1, and is therefore a polynomial of degree [itex]k[/itex].
(2) We have [tex](1 + x)^\alpha = \sum_{n=0}^\infty a_n x^n[/tex] where [tex]a_{n+1} = \frac{(\alpha - n)}{n+1}a_{n}[/tex] with [itex]a_0 = 1[/itex]. If [itex]\alpha[/itex] is a non-negative integer then [tex]a_{\alpha + 1} = \frac{(\alpha - \alpha)}{\alpha + 1}a_\alpha = 0[/tex] and thus [itex]a_n = 0[/itex] for all [itex]n > \alpha[/itex].
A compact way: [itex] 2^{n}=(1+1)^{n}=\int_{k=0}^{n}\begin{pmatrix}<br /> k\\<br /> n\\<br /> \end{pmatrix}1^{k}\cdot 1^{n-k}=\int_{k=0}^{n}\begin{pmatrix}<br /> k\\<br /> n\\<br /> \end{pmatrix}[/itex]
