Proving The Hamiltonian Is Invariant Under Coordinate Transformation
This discussion focuses on proving the invariance of the Hamiltonian under coordinate transformations, specifically transitioning from coordinates (q, p) to (Q, P) defined by the equations q = √(2P) sin Q and p = √(2P) cos Q. The participants confirm that if the Hamiltonian equations ∂H/∂q = -˙p and ∂H/∂p = ˙q hold, then the transformed equations ∂H/∂Q = -˙P and ∂H/∂P = ˙Q also hold true. Additionally, they derive the Hamiltonian for a one-dimensional harmonic oscillator, demonstrating that it simplifies to H = 2P when expressed in terms of the new coordinates, indicating that Q is ignorable.
  • Understanding of Hamiltonian mechanics and its equations.
  • Familiarity with coordinate transformations in classical mechanics.
  • Knowledge of derivatives and the chain rule in calculus.
  • Basic concepts of harmonic oscillators and their Hamiltonians.
  • Study Hamiltonian mechanics in depth, focusing on coordinate transformations.
  • Learn about the implications of ignorable coordinates in Hamiltonian systems.
  • Explore the derivation of Hamiltonian equations from Lagrangian mechanics.
  • Investigate the applications of Hamiltonian mechanics in various physical systems.
Students and researchers in physics, particularly those specializing in classical mechanics, Hamiltonian dynamics, and mathematical physics. This discussion is beneficial for anyone looking to deepen their understanding of coordinate transformations in Hamiltonian systems.
embphysics
(a) Consider a system with one degree of freedom and Hamiltonian H = H (q,p) and a new pair of coordinates Q and P defined so that q = \sqrt{2P} \sin Q and p = \sqrt{2P} \cos Q. Prove that if \frac{\partial H}{\partial q} = - \dot{p} and \frac{\partial H}{\partial p} = \dot{q}, it automatically follows that \frac{\partial H}{\partial Q} = - \dot{P} and \frac{\partial H}{\partial P} = \dot{Q}. In other words, the Hamiltonian formalism applies just as well to the new coordinates a to the old. (b) Show that the Hamiltonian of a one-dimensional harmonic oscillator with mass m = 1 and force constant k=1 is H = \frac{1}{2}(q^2 + p^2).(c) Show that if you rewrite this Hamiltonian in terms of Q and P defined in the two equations above, then Q is ignorable. What is P?(d) Solve the Hamiltonian equation for Q(t) and verify that, when rewritten for q, your solution gives the expected behavior.
All right, here is the solution I have written so far:
The system under consideration is constrained to move in such a way that its position can be adequately described by a single coordinate. In this case, the coordinate is q. However, there is another single coordinate that sufficiently describes the system's position, too, and that would be Q. The coordinate transformation between Q and q is q = \sqrt{2P} \sin Q. Given a position coordinate Q describing the system's position relative to some origin, we can find the corresponding coordinate q that describes the same location.
Here is where I am having trouble, writing the Hamiltonian as a function of q and p:
H(q,p) = \dot{q}p - L(q, \dot{q})
You do not need to know the Hamiltonian, just transform the variables. Both q and p are function of the new variables Q and P. Determine the partial derivatives of H and the time derivatives of the "old" p and q in terms of the new variables and their time derivatives.
ehild
All right, I am trying to find the velocity (the time derivative of q), and am running into a little difficulty with the chain.
$q = \sqrt{2P} \sin Q$. Because of this relationship, I will have to use the chain rule, becaus P and Q may both depend on time:
$\dot{q} = \sqrt{2 \dot{P}} \sin Q + \sqrt{2P} (\cos Q) \dot{Q}$
Did I properly apply both of those rules?
Think about your derivatives! E.g.,
\frac{\mathrm{d}}{\mathrm{d} t} \sqrt{2P}=\frac{\dot{P}}{\sqrt{2P}}.
vanhees71, why wouldn't there be a 2 in the numerator? For the generalized velocity, I get \dot{q} = 2\dot{P}(2P)^{-1/2} \sin Q + (2P)^{1/2}(\cos Q)\dot{Q}
\frac {\partial \sqrt {2P}}{\partial P} = (1/2) (2P)^{-1/2} \cdot 2
ehild
Oh, yes. Of course, I forgot the power rule. The more I look at this problem the more I am unsure as to how to proceed. Why don't I need to write the Hamiltonian out?
Derive the expressions both for dq/dt and dp/dt, and also write the partial derivatives of H with respect q and p in terms of derivatives with respect to the new coordinate Q and momentum P.
You do not need the Hamiltonian function itself, and you do not know it. Show that the relations are valid with the new coordinate and momentum, that is
\frac{\partial H}{\partial Q} = -\dot{P}
ehild
Okay, so for the generalized velocity I get \dot{x} = \frac{\partial H}{\partial p} \Rightarrow \dot{P}(2P)^{-1/2} \sin Q + (2P)^{1/2}(\cos Q) \dot{Q} = \frac{\partial H}{\partial p}. What does this show? I don't quite understand the purpose of these steps.
If you prefer to solve a) by writing out H try to do it.
I suggest to do questions b) and c) first.
ehild
I am not quite sure of what I'd prefer. Would the Hamiltonian look something like
H = p \dot{q} - L, where L = \frac{1}{2} \dot{q}^2 - U(q). I am not sure if this is correct, though. I don't believe I can assume the potential function is simply U(q), because that would be assuming the force is conservative, and that the PE is time independent.
If this does happen to be correct, of course, I would have to replace the generalized velocity with the generalized momentum.
Okay, so I am trying to solve part (b), and here is my attempt:
\dot{q} = \frac{\partial H}{\partial p} \Rightarrow \int \dot{q} dp = \int \frac{\partial H}{\partial p} dp \Rightarrow H = p \dot{q} + f(\dot{q})
and
\dot{p} = - \frac{\partial H}{\partial q} \Rightarrow \int \dot{p} dq = \int \frac{\partial H}{\partial q} dq \Rightarrow H = - \dot{p}q - g(q).
I know I need to solve for the constants of integration, but I can't recall as to how that is done. The thing is, however, that this method doesn't seem very promising.
Well, you need to prove that the Hamiltonian equations are valid for the new coordinate and momentum, for all cases. You do not know the Lagrangian function in general.
ehild
You know L or H for a one-dimensional harmonic oscillator in terms of the coordinate x and momentum p= mdx/dt. It is a conservative system. H is the total energy. Show that it is 0.5(p2+q2) if m=1 and k=1.
ehild
Oh, I see. I have class now, but I'll begin working on this problem as soon as I can.
Okay, so for part (b) and (c), here is my work:
Because the system is exhibiting simple harmonic motion, the forces acting on it can be described with Hooke's law; and because the force in Hooke's law depends only on position, it satisfies the condition of being a conservative force (is there a way of showing it satisfies the second condition, that the curl of the force is the zero vector?). From these circumstances, the Hamiltonian will simply be the total mechanical energy, \cal{H} = \mit{H} = T + U = \frac{1}{2} m \dot{q}^2 + \frac{1}{2} kq^2. The generalized momentum is p = \frac{\partial L}{\partial} \dot{q} = m\dot{q} \Rightarrow \dot{q} = \frac{p}{m}
Substituting this in, and simplifying, yields the desired result: \cal{H} = \frac{1}{2}(p^2 + q^2) (isn't this the square of the magnitude of the z vector in phase space?).
For part (c): Is it true that the only reason why we can proceed with part (c) is because we've proved (or, in my case, am still trying to prove) in part (a), that to write down the Hamiltonian in terms of different coordinates (a different way of measuring position) we can simply use the equations that relate the two coordinate systems (the transformation equations, if you will), and substitute directly into the Hamiltonian we found for the first coordinate system; that is, we don't have to derive a new Hamiltonian for the 2nd coordinate system. And is this all true provided the relationship between the two coordinate systems doesn't explicitly involve time?
Going off of this analysis, I get \cal{H} \mit = \frac{1}{2} [(\sqrt{2P} \sin Q)^2 + (\sqrt{2P} \cos Q)^2]. Because \cos^2 Q + \sin^2 Q = 1, the Hamiltonian reduces to \cal{H} \mit = 2P, from which we can see the Hamiltonian no longer depends on the generalized position Q, and the motion of the system can be described with the generalized momentum P.
Check factor 2. It should be H(P,Q)=P. So what is P in this case?
Go on with question d.
ehild
As for question a), the variables p and q are functions of P and Q
q = \sqrt{2P} \sin Q, p = \sqrt{2P} \cos Q
and P and Q are functions p and q :
P=\frac{p^2+q^2}{2}, Q=\arctan(q/p)
Apply the chain rule to write the Hamiltonian equations in terms of the new variables.
\frac{\partial H}{\partial q} = \frac{\partial H}{\partial Q} \frac{\partial Q}{\partial q} + \frac {\partial H}{\partial P} \frac{\partial P}{\partial q}
- \dot{p}=-\frac{\partial p}{\partial Q} \dot{Q} -\frac{\partial p}{\partial P} \dot{P} \rightarrow
\frac{\partial H}{\partial Q} \frac{\partial Q}{\partial q} + \frac {\partial H}{\partial P} \frac{\partial P}{\partial q} = -\frac{\partial p}{\partial Q} \dot{Q} -\frac{\partial p}{\partial P} \dot{P}
Do the same with the other equation \frac{\partial H}{\partial p} = \dot{q}, substitute the partial derivatives ∂P/∂q , ∂P/∂p, ∂Q∂q , ∂Q/∂p, and ∂p/∂Q , ∂p/∂P, ∂q/∂Q , ∂q/∂P. You get two equation for ∂H/∂Q and ∂H/∂P, solve for them.
ehild
