Proving the Inequality for Pseudoinverse and 2-Norm: Is ||A+|| ≤ ||A1-1||?
  • Thread starter Thread starter Codezion
The discussion revolves around proving the inequality ||A+|| ≤ ||A1-1||, where A+ represents the pseudoinverse of matrix A, and ||.|| denotes the 2-norm. The context involves matrix decomposition, specifically with A being partitioned into A1 and A2, where A1 is a nonsingular square matrix.
  • Exploratory, Assumption checking
  • Participants explore the relationship between the pseudoinverse and the norms of matrices, with one participant attempting to manipulate the expression involving A1 and A2. Others question the formulation of the problem and clarify the notation used, particularly regarding the definition of A dagger and the correct interpretation of the inequality.
The discussion is active, with participants providing clarifications and corrections regarding the problem statement. There is an emphasis on ensuring the problem is stated as it appears in the source material, indicating a productive direction in addressing potential misunderstandings.
Participants note confusion stemming from the latex syntax and the importance of correctly interpreting the problem as presented in the book. There is also a mention of the conditions under which A can be inverted, highlighting assumptions that may affect the discussion.
Codezion
Prove that the ||A+|| \leq ||A1-1||
Where A+=(ATA)-1AT, ||.|| is the 2 norm and A is an mxn matrix
A = [\stackrel{A1}{A2}] where A1 is an nxn nonsingular square matrix and A2 is any random matrix that is (m-n)xn
All I did was replace all the A's in the pseduoinverse with A1 and A2 and found the following:
||(A1TA1 + A2TA2)_1(A1 A2)|| but cannot proceed much. I really appreciate any help! Thank you.
Well, (A^TA)^-1=A^-1(A^T)^-1
So you get that A dagger equals A^-1 by definition, have you wrriten the problem as it is in the book?
You did not write the problem as specified in the book.
The book asks you to show that ||A^+||_2 \le ||A_1^{-1}||_2 . This is not the same as ||A^+||_2 \le ||A^{-1}||_2 . The latter does not even make sense because A can not have an inverse.
Thank you DH! I have corrected my problem - I think all the latex syntax confused me.
