Proving the limit (epsilon delta) #3
The discussion centers on proving the limit of the function as x approaches 8 using the epsilon-delta definition. The initial approach involves manipulating inequalities to establish the relationship between x and the limit, but there are concerns about the correctness of the steps taken. Key points include the need to ensure all terms are positive and the importance of correctly applying arithmetic laws in the proof. Participants emphasize the necessity of demonstrating that the chosen delta effectively supports the limit statement. The conversation highlights the complexity of epsilon-delta proofs and the importance of clarity in each step.
zeion
Prove the following states directly using the formal e, d definition
<br /> \lim_{x\rightarrow 8} \sqrt{x + 1} = 3<br />
If 0 < |x-8| < d
Then 0 < sqrt((x+1) - 3) < e
Let e be given
3 < sqrt(x+1) < e + 3
9 < x + 1 < e2 + 6e + 9
0 < x - 8 < e2 + 6e
This suggests we choose d = e2 + 6e
I assume you want comments on your work? I have three, of varying degrees of importance.
1. The work you've done here is "working backwards" -- you've started with what you wanted to happen, and worked backwards to try and find something that would ensure it.
Now, what you want to do is to show that this choice of d really does do what you want it to do.
2. When you did this step:
did you remember to make sure everything was positive? A relevant law of arithmetic is
If 0 < a < b then a² < b²​
3. Your translation from limit to e-d has an error.
Does this mean I need to show that sqrt(x+1) and e + 3 are positive?
Are you talking about the sqrt((x+1) - 3)? It should be sqrt(x+1) + 3?
And 3. (But notice that if you can show 3 is positive, then it's very easy to show the other two are positive)
It's obvious enough in this case that you don't need to bother mentioning it in your work -- but I want to make sure that you know what you're doing when you apply steps like this.
"sqrt(x+1) - 3", actually.
Yes I meant that sorry.
So now I need to show that
if 0 < x - 8 < e^2 + 6e
then 0 < sqrt((x+1) - 3) < e
is true?
is true?
(did you mean "|x-8|"?)
If you are still interested in finishing the e-d problem you originally wrote down, then yes that is what you need to do.
Sometimes it's possible to argue that all of your scratch work is reversible -- but it's probably not worth trying to do so until you become very comfortable with doing these arithmetic proofs involving inequalities.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
