Proving the Linear Transformation definition
13 replies · 2K views
Aleoa
HI .I'm trying to prove that, for a linear transformation, it is worth that:
[tex]f(a\bar{x}+b\bar{y})=af(\bar{x})+bf(\bar{y})[/tex] for every real numbers a and b.
Until now, I have proved by myself that
[tex]f(\bar{x}+\bar{y})=f(\bar{x})+f(\bar{y})[/tex].
and , using this result i proved that:
[tex]f(a\bar{v}) = f(\sum\bar{v})\text{(Sum it $a$ times)}[/tex].
[tex]=\sum f(\bar{v})[/tex].
[tex]=af(\bar{v})[/tex].
for every integer a.
How can I use this result in order to prove that
[tex]f(a\bar{v}) = af(\bar{v})[/tex]
for every [tex]a\in \mathbb{R}[/tex] ?
Hi @PeroK . Thanks for the reply.
I don't know, my book says it's possible to derive this result as i asked in my first post, even if it doesn't show how.
I upload the book's section I'm referring:
The book doens't start with the definition of Linear Trasformation, but try to deduce it.
Simply says that f is a one-to-one affine trasformation that keeps the origin fixed.
Before, it says that the affine trasformation is a trasformation that carries lines to lines
Don't you think it might have been important to say that in the OP?
I'm sorry. I'm here for improving :)
What i don't understand are the deductions done by my book, and you can see them in the 2 pictures i posted.
One thing I am not able to understand is how use this demonstration in order to prove
[tex]f(a\bar{v}) =af(\bar{v})[/tex].
for every rational a.
My book does this implicitly in this image, but i don't understand what it did...
I'm not sure about the picture, either. But it seems to me that if it's true for integers, it has to be true for rationals, as well.
##f(n \cdot \frac{x}{n}) = n f(\frac{x}{n})##
Therefore, ##f(\frac{x}{n}) = \frac{1}{n} f(x)##.
##f(\frac{m}{n} \cdot x) = m f(\frac{x}{n}) = \frac{m}{n} f(x)##
Thanks so much. Why can't i directly derive this proof to real values of a ?
Well, this is a pretty lame example, but suppose I define ##f(x)## this way:
  • If ##x## is rational, then ##f(x) = x##
  • If ##x## is irrational, then ##f(x) = 2x##
If ##q## is rational, then ##f(qx) = q f(x)##. But if ##q = \sqrt{2}## and ##x = \sqrt{2}##, then ##f(qx) = f(2) = 2##, but ##q f(x) = \sqrt{2} f(\sqrt{2}) = 4##
You need to know that ##f(x)## is continuous in order to prove ##f(qx) = q f(x)## when ##q## is irrational.
