Proving sum 1·2 + 2·3 + 3·4 + ... + n(n+1) = n(n+1)(n+2)/3 by induction
20 replies · 5K views
Bucs44
Here's my problem: 1 * 2 + 2 * 3 + 3 * 4 + . . . + n( n+ 1) = n(n + 1)(n + 2) / 3
I know that there is a Basis step and Induction step. For the Basis step I have the following but don't know if I'm on the right track: Basis Step 1 * 2 = 1 * 2 * 3 / 3 , which is true
I get lost at the Inductive step.
Any help would be appreciated
Welcome to PF,Bucs.
Which part of the induction step do you have a problem with?
Your basis step is right. Where, specifically, do you have problems?
edit: neutrino beat me to it!
Where I get stuck is what I should be inputing into the statement to verify it.
1*2*3 + n(n+1) = n(n + 1)(n + 2) / 3 +
I'm stuck on how to work the rest of the problem out.
You have to now prove that the above statement holds for n = k+1, assuming that is true for some positive k.
1.2+2.3+...k(k+1) + (k+1)((k+1)+1)
Now, you have to show it takes the form n(n + 1)(n + 2) / 3, for n = k+1.
I'm not sure that I'm following you - So it would look like this
n(n + 1)(n + 2) / 3 + k(k+1)
n(n + 1)(n + 2) / 3 + k(k+1)/3 / 3
1.2+2.3+...k(k+1) + (k+1)((k+1)+1) ---> This is for k+1
Since we've assumed that it holds true for some arbitrary k greater than 1, we can write
1.2+2.3+...k(k+1) = k(k + 1)(k + 2) / 3 (1)
Now,
1.2+2.3+...k(k+1) + (k+1)((k+1)+1) = k(k + 1)(k + 2) / 3 + (k+1)((k+1)+1) (refer(1))
Simpligy the right-hand side to (k+1)(k+2)(k+3)/3, which is what you would get if you put n = K+1 in n(n + 1)(n + 2) / 3
Thanks for all of your help neutrino - I think the whole Inductive step is what is really fowling me up - my algebra is poor at best.
Can I ask you 1 more question though?
2n + 1 < 2n, n = 3, 4 …..
Basis Step (n = 3) - 2(3) = 6 + 1 = 7 < 23 = 8 so we Assume true for n
Am I on the right track?
:confused:
Are you sure that's the question?
and this whole part...
doesn't make sense.
I thought by plugging in either 3 or 4 as n that it would be true. I have to verify the inequality
This cannot be the correct question, since 2n+1>2n for all n!
14. 2n + 1 < 2n, n = 3, 4 …..
It should be less than or equal to - it just didn't come through when I pasted it.
Should it not read something like [itex]2n+1\leq 2^n[/itex] for n=3,4,...?
See - I really am bad at this stuff - the way you have written it is correct.
From my above post I guess my Basis Step is wrong?
Well, your basis step: It is true for n=3 so assume true for n=k by the inductive hypothesis. So, we know that [itex]2n+1\leq 2^n[/itex], for n=3,...,k, and we want to show true for n=k+1. So, we have [itex]2(k+1)+1=2k+2+1[/itex]. Can you invoke the fact that we know is true (i.e. it holds for n=k) into this equation?
If you think that 2n, when n= 3, equals 23, this may be hopeless. Do you know what "2n" means?
I'm not sure what you mean by "it holds for n=k"
You have proven by your inductive hypthesis that [itex]2k+1\leq 2^k[/itex]
That's all that's to that problem? I thought it would be much more difficult than that.
Well, if you've shown that [itex]2k+1\leq 2^k \Rightarrow 2(k+1)+1\leq 2^{k+1}[/itex], then yes, the problem is solved.
