Proving Trig Identities with Complex Numbers
22 replies · 6K views
Oblio
Consider the complex number z=e[tex]_{i\theta}[/tex] = cos[tex]\theta[/tex]+isin[tex]\theta.[/tex] By evaluating z[tex]^{2}[/tex] two different ways, prove the trig identities cos2[tex]\theta[/tex] = cos[tex]^{2}[/tex][tex]\theta[/tex] - sin[tex]^{2}[/tex][tex]\theta[/tex] and sin2[tex]\theta[/tex] = 2sin[tex]\theta[/tex]cos[tex]\theta[/tex].
A question about the approach to this question:
How do you guys approach the task of 'evaluating' something, when told to do so, like here.
I find myself doing random manipulations without knowledge of whether the road I'm on is even close to the correct path or not.
Evaluate seems like such a general instruction...
Anyways,
If I square z I get;
z[tex]^{2}[/tex] = cos[tex]\theta[/tex][tex]^{2}[/tex] + i[tex]^{2}[/tex]sin[tex]\theta[/tex][tex]^{2}[/tex]
z[tex]^{2}[/tex] = cos[tex]\theta[/tex][tex]^{2}[/tex] - sin[tex]\theta[/tex][tex]^{2}[/tex]
If I sub z[tex]^{2}[/tex] back in I get 0 so that's wrong.
Is the use of the 'e definition' necessary for this? I kind of want to see how I ought to be approaching this 'evaluation'.
Thanks, as always
How??
If [tex]z = \cos{\theta}+\imath\sin{\theta}[/tex], then [tex]z^2 = \left(\cos{\theta}+\imath\sin{\theta}\right)^2 \neq \cos^2{\theta}+\imath^2\sin^2{\theta}[/tex].
Square that. Then use the other way of evaluating a complex number raised to some power, i.e., de Moiver's formula. Equate the two.
Am I allowed to do this?
isin[tex]\theta[/tex][tex]^{2}[/tex]
=-sin[tex]\theta[/tex][tex]^{2}[/tex] ?
The way you have written is quite ambiguous. But if you mean [tex]\left(\imath\sin{\theta}\right)^2[/tex], then it is equal to [tex]-\sin^2{\theta}[/tex].
P.S. You need not enclose each term of LaTeX code within 'tex' tags. It is enough if you do it for each line of code. Example: Enclosing this - \left(\imath\sin{\theta}\right)^2 - within tex tags will produce [tex]\left(\imath\sin{\theta}\right)^2[/tex]. :smile:
lol thanks!
It just does that when I click the latex icon each time.. your saying you write it all out manually?
I'm still stuck with:
z[tex]^{2}[/tex] = cos[tex]^{2}[/tex][tex]\theta[/tex] + 2isin[tex]^{2}[/tex][tex]\theta[/tex] - sin[tex]^{2}[/tex][tex]\theta[/tex]
You'll see I still did it the long way if you quote:P
Oblio said:
lol thanks!
While I mostly do it manually(click n' latex is only a recent feature), I'm not asking you to do it manually.
When I click on any icon, what I get is that piece of code (say, \frac{}{} for fraction) within tex codes. The cursor is still within the those tags, so when I click on another icon, only its code is printed within the same set of tags. When I want to do a new line, I move the cursor outside the first set of tex tags.
Shouldn't it be [tex]\cos^2{\theta} + 2\imath\cos{\theta}\sin{\theta} - \sin^2{\theta}[/tex]?
yeah, sorry. Typo
Did you also find the other expression using de Moivre's theorem/formula?
oh i equate the 2 just for one of the two I am looking for? I thought that was for the other equation
What do you get when you equate the two?
I've gotten to
cos2[tex]\theta[/tex]=cos2[tex]\theta[/tex]-isin2[tex]\theta[/tex]+2isin[tex]\thetacos\theta[/tex]
im realizing now that's wrong isn't it..
Oblio said:
I've gotten to
When is a + ib = c + id? (a,b,c,d are real)
Right.
So when you equate cos(2t) + isin(2t) and cos^2(t) + 2isin(t)cos(t) - sin^2(t)...?
(using 't' instead of theta.)
well if i use what I am trying to prove,
cos(2t) = cos^2(t)-sin^2(t)
and sin(2t) = 2sintcost
but doesn't this method require that which I am proving, to prove it?
No. You're just equating the real and imaginary parts of the complex numbers. All you're using is the definition of equality of two complex numbers. (a = c, b = d)
So is it a valid proof to say that
cos2t +isin2t = cos^2(t) + 2isintcost - sin^2(t)
cos2t must = cos^2(t)-sin^2(t)
sin2t=2sintcost ?
They must be equal since the corresponding real and imaginary components are equal.
I think writing the RHS as (cos^2(t) - sin^2(t)) + i(2sin(t)cos(t)) will make things familiar to you.
Ok.
If the i's cancel leaving:
cos2t + sin2t = cos^2(t) - sin^2(t) + 2sin(t)cos(t)
There are all real parts. You don't think I'll need to prove the two RHS pieces?
