Proving uniqueness of limits using delta-epsilon definition
7 replies · 17K views
Kelvie
Good evening,
I am a first year engineer here and a first time poster also.
I had a problem that has been bugging me for the last few days; after much head-scratching and tree-killing, I may have solved it. I am, however, not sure at all if all my assumptions along the way are correct. So I am here to seek wisdom.
The question deals with proving the uniqueness of limits.
Prove that all limits are unique.
The textbook got me started, it said to define
[tex]\lim_{x\to a} f(x) = L[/tex]
[tex]\lim_{x\to a} f(x) = M[/tex]
Assume [itex]L \neq M[/itex] and let [itex]\frac{|L - M|}{3} = \epsilon[/itex]
So here goes my proof..
[tex] \begin{align*}<br /> &|L-M| = |L -M + f(x) - f(x)| = |(L-f(x)) + (f(x) - M)| \\<br /> &|L-M| \leq |-1||f(x) - L| + |f(x) - M| = |f(x) - L| + |f(x) - M|<br /> \end{align*}[/tex]
So by definition..
[tex] \begin{align*}<br /> 0 \leq |x-a| \leq \delta (\epsilon) \implies \substack{|f(x) - L| \leq \epsilon \\ and \\ |f(x) - M| \leq \epsilon} \\<br /> \end{align*}[/tex]
[tex] \begin{align*}<br /> \therefore |L-M| &\leq 2\epsilon \\<br /> |L-M| + \epsilon &\leq 3\epsilon \\<br /> |L-M| + \epsilon &\leq 3 \left(\frac{|L-M|}{3}\right) \\<br /> |L-M| + \epsilon &\leq |L-M|<br /> \end{align*}[/tex]
Which can not possibly be true, so I conclude that our initial assumption [itex]L \neq M[/itex] was false, and therefore L must equal M.
Is this not the way to answering the question? If not, how should I look at this problem? What should I have done differently? What other approaches should I take?
(Side note... I REALLY hate delta-epsilon proofs..)
"So I am here to seek wisdom."
Seek and ye shall receive! (Welcome to PF!)
Yep, you've got it.
Nope, those proofs are cuties..
So this is "hand-in"able? :P
Thanks for the timely reply, by the way.
It is much easier in words. i.e. if L is the limit of f(x) as x approaches a, then the inverse image of every interval centered at L contains a punctured interval centered at a. same for M. But this is a contradiction if Ldoes not equal M, since then L,M are centers of disjoint intervals whose inverse images are thus disjoint. But no two punctured intervals centered at a are disjoint.
the only place epsilon is needed is to describe the size of the disjoint intervals centered at L,M, namely |L-M|/3.
Alright, this also makes sense, doesn't it?
We ignore the assumption [tex]L \neq M[/itex] and [tex]\epsilon = \frac{|L-M|}{3}[/itex]<br /> [tex] \begin{align*}<br /> &|L-M| = |L -M + f(x) - f(x)| = |(L-f(x)) + (f(x) - M)| \\<br /> &|L-M| \leq |-1||f(x) - L| + |f(x) - M| = |f(x) - L| + |f(x) - M| \\<br /> &|L-M| \leq |f(x) - L| + |f(x) - M|<br /> \end{align*}[/tex]<br /> [tex] \therefore |L-M| \leq 2\epsilon[/tex]<br /> <br /> And since [itex]\epsilon[/itex] is can be as arbitrarily small as we want it to be, [itex]L-M[/itex] must equal 0. Is this also correct? <br /> <br /> Side note: When using [itex]\delta - \epsilon[/itex] proofs, do we use [itex]\leq[/itex] or [itex]<[/itex], or does it not matter? My prof uses the former, and the textbook uses the latter.<br /> <br /> Can I still assume [itex]|L-M| = 0[/itex] if I use [itex]\leq[/itex] ? Or do I have to have it strictly less than [itex]\epsilon[/itex]?[/tex][/tex]
that looks nice. as to your question, ask your self: is it true that if L is such that
0<= L <= a, for all positive a, then L is zero?
also: is it true that if L is such that
0<= L > a, for all positive a, then L is zero?
If by the second statement you meant [itex]0 \leq L < a[/itex] then yeah, I guess they are equivalent statements.
Thank you for your help.
