Proving when operator commutators equal zero
4 replies · 2K views
Bravus
http://www.bravus.com/question.jpg
See below
Below are my scribbles toward a solution. The point is that the two expressions are different *unless* either the operators A and B or the operators B and C commute.
Not really looking for someone to solve it completely, but this is one of those questions I'm just looking at blankly to figure out how to start... yeah, I suspect I'm not smart... ;-)
http://www.bravus.com/scribbles.jpg
Hi! In my opinion it is easier to proceed in the following way: consider the case in which A and B commute (the other case is analogous); in this case there exists a common set of eigenstates; this induce in the formula you want to prove a lot fo deltas (eigenstates corresponding to different eigenvalues are orthogonal); this equation can now be easily verified.
Francesco
Thanks, Francesco. That kinda makes sense to me. But I'm a little unclear.
The fact that A and B commute means there *exist* simultaneous eigenkets, |ab> of both A and B.
I don't think that means, though, that |a> and |b> are *necessarily* all simultaneous eigenkets.
And they would need to be, for the solution you propose to work, yes?
You are welcome; in any case, the correct statement is: let A and B be commuting operators with nondegenerate eigenvalues; then, if [itex]|a\rangle[/itex] is an eigenstate of A, [itex]|a\rangle[/itex] is also an eigenstate of B; moreover, if [itex]|a\rangle[/itex] and [itex]|a'\rangle[/itex] are two eigenstates of A corresponding to different eigenvalues, then they are eigenstates of B corresponding to different eigenvalues.
I hope I have been clear.
Francesco
