Proving XOR Gate Universality: Elementary Operations & Logical Manipulation
  • Thread starter Thread starter braceman
    Gate Universal
10 replies · 4K views
braceman
Hi guys, got a question that's got me stumped. Not looking for the answer as I'd prefer to work it out myself, just a nudge or a pointer in the right direction.
I'm being asked to prove if an XOR gate can be classed as universal (like the NAND & NOR gates are), but not sure how to go about it. I think there must be a simple way to do it, rather than draw numerous combinations of XOR gates.
Determine the elementary operations that can be derived from XOR and hence determine if it is a universal gate.
Obviously got the truth table for XOR, am I supposed to be manipulating this, or taking a function, ie - F = A.B + C. not A and then trying to manipulate this like we do when converting to NAND/NOR (changing gates and inverting terms etc).
Bit stuck, so any pointers would be grateful.
Sorry, misread your post. Look into definitions or requirements of a universal gate.
To prove that gate type X is "universal", you just need to show that the Boolean functions AND, OR, and NOT can be implemented using only gate type X without the need for any other type gate. Can you do that with an XOR gate?
Or prove that you can make a single NOR or NAND gate
here is a hint. first see if you can make an inverter
then see if you can make any input a 'blocker.' an example of that is an and gate, if any input is a zero, the ouput will be zero, independent of any other input
Here's another hint: Try to prove you can't make an AND gate. (I don't think this is so easy to show if you haven't seen an argument before though).
Sorry I haven't posted back...forgot all about this post. I got it right in the end, Instructor said I could prove it however I wanted, so I just drew various combinations of 3-4 gates and their associated logic.
Is it correct that AND and OR cannot be derived from XOR at all?
what do you think, and why?
What I meant is that an AND or OR gated cannot be derived by using only XOR gates. We can however make an inverter out of a XOR gate by connecting constant high to one of its input but I can't see any possible way to get either AND or OR from only XORs. To account for that I would say XOR gives high output only if its two inputs differ.
I agree.
