Pulley Acceleration and Tension Relations
  • Thread starter inv4lid
    Pulley
inv4lid
Determine bodies' acceleration if their masses are the following: m1 = 25kg, m2 = 1kg, m3 = 3kg and the Tension of the ropes. Friction is neglected, as well as the mass of the pulley. It is considered that the ropes are perfect.
Hand-drawn diagram of an Atwood-style pulley system: a pulley with tensions T1 and T2, block m1 hanging on the left, m2 and m3 stacked on the right, weights G1, G2 and G3 labelled, with a vertical y-axis pointing up on the right.
m1 = 25kg;
m2=1kg;
m3=3kg;
___________
a=?
T1=?
T2=?
For the first object we have:
T1-G1= m1*a; (the acceleration is oriented upwards)
a = (T1-G1)/m1;
For next ones, I guess:
The acceleration here goes downwards
T2-G2-G3 = -(m2+m3)*a;
a = (T2-G2 - G3) / -(m2 + m3)
Are the accelerations the same?
How would i find it?
  • Hand-drawn diagram of an Atwood-style pulley system: a pulley with tensions T1 and T2, block m1 hanging on the left, m2 and m3 stacked on the right, weights G1, G2 and G3 labelled, with a vertical y-axis pointing up on the right.
What would happen if the accelerations were not the same?
You may safely assume that this is an ideal pulley, i.e. it changes the direction of the tension but not its magnitude. This will simplify your work.
I need to get some numbers. How would i get the tension/acceleration? There is too much unknown data.
(i guess we can't get any of T)
I think kuruman is trying to get you to relate ##T_{1}## to ##T_{2}##. If the pulley is ideal (frictionless and massless) what is the relation? Once you have the relation, you can solve the algebraic system.
