Pulleys reduce the work needed
  • Context: Undergrad
  • Thread starter Thread starter Ebolamonk3y
    Pulleys Work
Pulleys do not reduce the total work required in a physics context; they reduce the force needed by increasing the distance over which that force is applied. The relationship is defined by the equation work = force times distance. Adding an infinite number of pulleys does not yield a productive outcome, as it leads to nonsensical scenarios involving infinite force and distance. The discussion emphasizes the importance of avoiding infinite concepts in practical physics applications.
  • Understanding of basic physics concepts, specifically work and force
  • Familiarity with the mechanics of pulleys and their function
  • Knowledge of the relationship between force, distance, and work
  • Basic grasp of mathematical limits and the concept of infinity
  • Study the principles of mechanical advantage in simple machines
  • Learn about the physics of tension and compression in ropes and cables
  • Explore the implications of infinite series in physics and mathematics
  • Investigate real-world applications of pulleys in engineering and construction
Students of physics, mechanical engineers, and anyone interested in understanding the practical applications and limitations of pulleys in mechanical systems.
Ebolamonk3y
clarify this for me...
I know that pulleys reduce the work needed, depending on how its setup... But let's say at you add n number of pulleys to mass... And the work is reduced by 1/n... So you add infinite amount of pulleys... and then you supply an infinity amount of force... inf/inf = ? What exactly are you getting here? Tug 5m... with 5 pulleys in this setup its just 5/5...hmmm confused.
Just a little warning: Stay away from infinities. They do nothing productive.
cookiemonster
Gravity... couldn't you use that to supply the pull of this pulley?
Er... Gravity...?
The problem is an infinite amount of force is a tricky thing to handle. Combine it with an infinite number of pulleys and we have an even more difficult (i.e. impossible) problem to handle.
Simply put, infinity doesn't exist in physics, so don't try to force it in there.
cookiemonster
Whats about finite? what if the rope itself can expand or shrink... and you have to tug at it as it shrinks... then wouldn't you do less work? or... am I confusing myself...
I don't know about yourself, but you're certainly confusing me. =\
cookiemonster
heh... nvm then.
Work would be the SAME except for increased losses.
Force decreases with the addition of pulleys and rope displacement increases.
You would quickly exceed the rope's strength well before reaching infinity, and at some point the drag of all the pulleys and sheer mass of rope between them needs to be included in the calculation. Just having an infinite length of rope would have huge mass and then an infinite force would cause the rope to exceed its tensile strength and break, no pulley's needed.
Cliff
Pulleys do NOT reduce "work needed"- not in the physics sense of the word "work". They reduce the force needed in "work= force times distance" by increasing the distance over which the force is applied.
If you attached an "infinite" number of pulleys you would use 0 force for an "infinite" distance- which means nothing, physically. As CookieMonster said, "Stay away from infinities"!
cookiemonster said:
Just a little warning: Stay away from infinities [in situations where they don' belong]. They do nothing productive.
Wise words.
[beaten to death, but eh...]
No, actually, pulleys keep the work exactly the same (assuming no losses of course). Double the number of strands and you get twice the force at half the displacement on one side and twice the displacement for half the force on the other.
alright... thanks for the clarification.
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 29 ·
