Pump NPSHA (net positive suction head) question
The discussion revolves around the calculation of static Net Positive Suction Head Available (NPSHa) for a pump in a flooded suction scenario, specifically in the context of a hotwell from a condensing turbine exhaust. Participants explore the implications of suction head, vacuum conditions, and the effects of atmospheric pressure on pump operation.
  • One participant inquires about the static NPSHa with a flooded pump suction of 10 feet and a vacuum of 27" Hg, seeking to understand the implications for pump operation.
  • Another participant calculates the head available at the pump inlet, combining the suction head and pressure from the vacuum, while noting potential friction losses in the piping.
  • Follow-up questions arise regarding the effects of opening a blow-off valve on the pump suction strainer, with some participants agreeing that it would introduce air into the system.
  • Participants discuss the concept of why a pump can only lift water to a maximum height of 34 feet due to atmospheric pressure, questioning why the vacuum above the water does not similarly lift the water in the hotwell.
  • One participant reflects on their understanding of the mechanics involved, noting that atmospheric pressure is responsible for pushing water up to the pump rather than the pump itself creating a lift.
  • Anecdotal experiences are shared regarding historical challenges faced in pump operation related to vacuum and pressure dynamics.
Participants express a mix of agreement and uncertainty regarding the mechanics of suction lift and the role of atmospheric pressure, with no clear consensus on the implications of vacuum conditions in the hotwell scenario.
Discussions include various assumptions about system layout and conditions, with some participants acknowledging limitations in their understanding of how vacuum affects water lifting in different contexts.
Individuals interested in pump operation, fluid dynamics, and engineering principles related to suction and pressure in hydraulic systems may find this discussion relevant.
Dennis C
Simple (I hope) pump question.
With the pump not even running, would like to know what my static NPSHa is if I had a flooded pump suction with 10 feet suction head of water and a vacuum of 27" Hg above the water?
Basically it is the hotwell from a condensing turbine exhaust after the steam is condensed.
We hold a 10 foot suction head and it is under vacuum with steam temp about 115 degrees above it in the hotwell tank
Thank you for your time
The head available at the pump inlet will be 10 feet of water + about 3" Hg or
10*62.4/144 = 4.33 psi + 1.43 psi = 5.76 psi less any friction losses in the piping when the condensate starts to flow.
Here's a better description of calculating NPSHA:
http://www.pumpschool.com/applications/NPSH.pdf
Thank you SteamKing!
Excellent info from the link also.
I take it the 1.43 psi is from the 3" Hg , (29.9 =14.7, roughly 2 to 1 ratio) and the total is what I thought it should be.
Now, two follow up questions.
If I open the blow off valve on the pump suction strainer, it will suck air in, so it is under a vacuum at the pump inlet, (Agree?)
Also, I understand why a pump can only "lift" water 34 ft (suction lift, not flooded) due to atmospheric pressure pushing the water up to the pump.
so why isn't the vacuum above the water trying to lift it like a pump lifting water by producing a vacuum?
Uhhh, I think I just answered my question with the "atmospheric pressure pushing the water up to the pump.
There is no pressure to push it up, correct?
Thank you so much for the help. I believe the last question is critical to my understanding
It's not clear why you would want to do that.
You want to make sure that the NPSHA > NPSHR for the pump, in all flow regimes. If NPSHA is not sufficient, the pump will cavitate and damage the impeller.
"It's not clear why you would want to do that"
I don't want to but I know if I do, it will suck air, (I've done it quickly to confirm my suspicion) so if I installed a pressure gauge, what would it read? 5 to 6 psi? or vacuum?.
I understand the A has to be greater than R, just wondering why if I produce a vacuum to lift water with a pump, why this water doesn't "lift" and starve the pump.
Ex. a well pump on top producing suction lift, lifts the water by producing a vacuum, but the vacuum in my hotwell doesn't "lift" away from my pump below.
I can't really say, since I don't know how your system is laid out.
If a well gets too deep, then the pump must be placed at the bottom of the well and force the water to the surface. At least, that's how it was done when my household water was provided by a well (about 90 feet deep) drilled in my backyard.
Thank you, I have a much better understanding now!
Boring Anecdote ∞-1...
When our power plants were small ,,,
"priming" the condenser waterbox doused the turbine deck with salt water, as the steam jet priming ejector was located only twenty feet or so above the seawater intake .
When starting the first "huge" 160 mw plant , operators were flustered: " Cant get the waterbox primers to blow saltwater, but vacuum is fine.. ? ?"
Resident engineer shouted "Eureka! Let's go back and move all our priming jets up above 32 feet !"
Jim,
Good story!
I believe it was Galileo and Torricelli who figured out that due to atmospheric pressure, a pump can only lift water a max of 34 ft .
That I fully understand. It's actually the atmospheric pressure pushing the water up the well to the pump and not the pump "sucking" it up.
Thanks!
