Can a Vortex Effectively Purify Water by Utilizing Gravity?
  • Thread starter Thread starter watersplit
    Vortex Water
The discussion centers on the effectiveness of using a vortex and gravity to purify water. One method proposed involves creating a funnel-like jar to allow heavier particles to settle at the bottom over time. The idea is that unclogging the jar would create a vortex, potentially accelerating the removal of impurities. However, experts argue that this method primarily addresses solid particles and does not effectively remove dissolved contaminants, such as salts or chemicals, which do not settle. They emphasize the importance of defining "purification" based on the intended use of the water, noting that traditional filtration methods are more reliable and efficient for removing both solids and dissolved impurities.
watersplit
TL;DR
Purify water with vortex / law of gravity - good or bad?
What do you think of purifying water by using a vortex / law of gravity?
Here is what I am thinking:
1. Build a funnel-like jar, clog it on the bottom and fill the jar with water. Now wait for several hours.
2. Unclog the bottom, wait for a few seconds (depending on the size of the jar) and then clog it again.
It is my belief that heavier particles than water will fall to the bottom. And if you also unclog the bottom then a vortex will be created which will suck the impurities down even faster. What impurities will be left? The ones that weights less than water, which could either be boiled off or trapped in a filter. Again, it's only what I think, I am not an expert.
What do you think, is this a good purifying technique?
Chemistry news on Phys.org
Try using a filter funnel and filter paper. More effective, existing technology, tried and tested for a few hundred years, much faster than what you are suggesting.
Basically, you are describing letting heavier solid particles, such as bits of mud, settle and hoping to wash them away. Normally when this is used, we decant the liquid off the top of the settled sediment. If we want to wait a few hours, rather than filter it.
Now if you are thinking of separating something that is dissolved in the water, say sodium chloride or ethanol or some soluble contaminant, you are on a loser. It will not work. It will not make purer water. Dissolved substances do not settle to the bottom of a liquid.
In short: define "purify". For some uses removing just solid particles will be OK, for other uses things that are left dissolved are much worse.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
  • · Replies 42 ·
  • · Replies 20 ·
19K
  • · Replies 39 ·
15K
  • · Replies 17 ·
