How to Calculate the Work Done When Pushing a Ball Underwater?
  • Thread starter Thread starter Drektjal
    Ball Underwater
The discussion focuses on calculating the work done when pushing a ball with a radius of 15 inches underwater, specifically when it is submerged halfway. The key formula for calculating the buoyant force is given as N = ρVg, where ρ is the water density, V is the volume of the submerged part of the ball, and g is the acceleration due to gravity. The average volume of the submerged portion is incorrectly proposed as V_{Av} = ∑V_n/∞, but it is clarified that an integral approach is necessary for accurate calculation, as the concept of limits and integrals has not yet been taught to the student.
  • Understanding of buoyancy and Archimedes' principle
  • Familiarity with basic physics equations involving force and work
  • Knowledge of calculus concepts, particularly integrals
  • Basic understanding of volume calculations for spherical objects
  • Study the concept of integrals and their application in physics
  • Learn how to calculate the volume of a sphere and its submerged portion
  • Explore buoyancy calculations and the role of density in fluid mechanics
  • Review the principles of work and energy in physics
Students studying physics, particularly those focusing on fluid mechanics and work-energy principles, as well as educators seeking to clarify these concepts for their students.
Drektjal
A ball of which radius is 15 inches is put into water and it sinks 2.5 inches. How much is the work done when it's pushed halfway under water?
Air pressure doesn't have to be taken into account (not sure about that but that one I can do myself anyways).
Lift by the water (the weight of the ball can be calculated with this):
N=\rho Vg
Average V of the part of the ball that is underwater is (this one I made up myself):
V_{Av}=\frac{ \sum^{\infty}_{n=0} V_{n}}{\infty}
WhereV_{n} is the volume of the ball underwater when the ball is up to its \frac{n}{\infty}*r underwater (where r is the radius of the ball).
Work done:
W= \rho V_{Av}g * 15 inches - mg * 15 inches (Where m is the mass of the ball and W is the final answer. )
I can do everything else in this exercise except I can't calculate V_{Av}=\frac{\sum ^{\infty}_{n=0} V_{n}}{\infty} (the hard part is getting the \infty out of the expression) but I'm not even sure if it's supposed to be calculated this way as we haven't been taught the concept of \sum.
This exercise is one of the preliminary exercises that came with my physics book so it's not homework or something like that and therefore I'm not interested in the exact answer but rather the theory and easiest way to solve it.
Thanks in advance for any kind of help.
Since it says you don't have to worry about that I imagine you can!
N=\rho Vg
You can't do it as a sum and you don't have "infinity" in it- if you want to do it exactly you will need to use an integral, not a sum.
-So you'd recon there's no other way around this than that as integral is also something that hasn't been taught to us (if I remember right I don't have the integral-class in maths until next semester)?
Thanks for the quick answer though!
