How Do You Calculate Final Pressure in an Expanding Gas Scenario?
  • Thread starter Thread starter cuddlylover
    Pv=nrt
The discussion centers on calculating the final pressure of an ideal gas using the combined gas law, specifically the equation P1V1/T1 = P2V2/T2. The initial conditions are an initial volume of 500 cm³, an initial temperature of 20°C, and an initial pressure of 2 atm, which converts to 202650 Pa. The final volume is 1000 cm³, and the final temperature is 60°C. Participants emphasize the importance of converting all figures to base units for clarity and accuracy in calculations.
  • Understanding of the ideal gas law and combined gas law
  • Ability to convert units, particularly pressure from atm to Pa
  • Basic algebra skills for manipulating equations
  • Familiarity with temperature conversion from Celsius to Kelvin
  • Learn how to apply the combined gas law in various scenarios
  • Study unit conversion techniques for pressure and temperature
  • Explore real-world applications of the ideal gas law in engineering
  • Review algebraic manipulation of equations for solving physics problems
Students in chemistry or physics courses, educators teaching gas laws, and anyone needing to solve problems related to gas behavior under changing conditions.
cuddlylover
PV=nRT Need help asap :)
An ideal gas has an initial volume of 500 cm3, an initial temperature of 20C, and an initial
pressure of 2 atm. What is its nal pressure if the volume is allowed to expand to 1000 cm3
while the temperature increases to 60C?
Im trying to work this out i have got it to 2atm.500cm3/293k = p2.1000cm3/333k but can't work out how to get p2.
If someone could point me the right way would be a big help.
Hello cuddlylover
First off, I'd strongly recommened that getting into the habbit converting all figures into base units. This makes things easier for much tougher problem solving questions so:
Convert 2atm would = 2(101325)pa
anyway...
Lets look the formula:
I think the formula you're using is incorrect, in the title, you are using the ideal gas equation. whereas, I think you need the combined gas law which is:
\frac{PV}{T} = k
or
\frac{PV}{T}=\frac{PV}{T}
If you wanted to find P on the right hand side, take T then V to the other side ;)
Thanks for that. You where right i was using the combined gas law.
Are you able to give me a little more info on
"If you wanted to find P on the right hand side, take T then V to the other side ;)"
Sorry I am a comp sci major being made to do this :)
No worries, we all have our strengths are weaknesses :P
... finish this sentence...
because the T on the right hand side is divided by, on the left and side it will be...
and this one
because the V is being multiplied by on the right hand side, on the left it will be...
Now take the T and the V to the left hand side of the equation
Since when does a computer science major claim he is unable to do high school chemistry due to his major?
pv=nrt
n and r are constants. We see then that
\frac{pv}{t} = nr
This means
\frac{p_1v_1}{t_1} = \frac{p_2v_2}{t_2}
and this one
I am pretty sure he is not having problems doing algebra...
miniradman said:
Hello cuddlylover
anyway...
\frac{PV}{T} = k
or
The formula is not incorrect. Calling upon an arbitrary manipulation of gas law and renaming it "combined gas law" is just plain confusing. You should just show him the common sense manipulation of gas law.
Still not getting it so if i have p1.v1/t1 = p2.v2/t2 i can just more them over to make p1.v2/t2 and that will give me p1?
I'm not sure the answer can be any clearer. Just remember to watch your units.
