QED functions E(a to b) and P(a to b)
In summary: I think.In summary, Feynman is talking about how the amplitude of probability waves is related to the history of a particle. He says that P(e1,e2) is almost equivalent to E(e1,e2)... where e1 and e2 are event1 and event2. He also says that the propagator is the amplitude also.
Cemre
Hello all...
I confess, I didn't make much googling about this, so if this question is
already answered :) just show me the link to answer...
In his famous video lectures about quantum electro dynamics,
Richard Feynman is talking about electron and photon functions
E and P. And whole story is about path-integrating those functions.
In wikipedia it is as follows:
If a photon moves from one place and time – in shorthand, A – to another place and time – shorthand, B – the associated quantity is written in Feynman's shorthand as P(A to B). The similar quantity for an electron moving from C to D is written E(C to D).
In Feynman's lectures, he says P is related to ( 1 / ( (t^2) - (x^2) ) )
( minus; reminding of relativity )
What exactly are those E and P functions? ( formula? )
Thanks.
What is referred to is the amplitude of probability waves calculated from the difference in location of the 'particles'
To give a formula,. you would need a summation of the squares of all possible path trajectories between the 'particle' at point A and the particle at point B.
Hi,
yes, yes, I know that E and P are functions that take a couple of positions and time, one for location 1 , one for location 2, and give out a complex number which is the probability amplitute. I know about probability amplitutes.
path-Integrating complex functions E and P gives the total probability, I understand that.
But :) what exactly are E and P ( like F is F=ma )
Thanks.
Cemre said:
Hi,
Thanks.
They are just to distinguish between the Electron (E) and Photon (P)
Feynman says in his lecture that
in fact P(e1,e2) is E(e1,e2) where rest mass is set to zero.
But he doesn't give the open formula for E(e1,e2)
I would appreciate very much if someone could give me the open formula for E(e1,e2)
_PJ_ , you still don't understand what I am asking...
Are they green's functions and if it's so how they have been calculated?
Hi again,
I think I found something...
at wikipedia : http://en.wikipedia.org/wiki/Path_integral_formulation
Feynman's interpretation :
3. The contribution of a history to the amplitude is proportional to e^{i S/hbar}, where hbar is reduced Planck's constant, and can be set equal to 1 by choice of units, while S is the action of that history, given by the time integral of the "Lagrangian" along the corresponding path.
--> given by the time integral of the "Lagrangian" along the corresponding path
also another wiki article has information about QED Lagrangian.
"Quantum electrodynamic Lagrangian" :
at wikipedia : http://en.wikipedia.org/wiki/Lagrangian
Need verification...
Are those correct ?
Thanks.
You might try looking in Feynman's book QED: the Strange Theory of Light and Matter. It's been many years since I read it, but as I recall Feynman used very sloppy and imprecise language to describe the math, incorrectly referring to a propagator as a quantum amplitude. So, if you're interested in learning the real theory, Feynman is not the best source.
I've never read that particular book, but I'm a big fan on his lectures in physics, volume I.
I vaguely recall Peskin and Schroeder saying that the propagator is the amplitude also, although I've never read their book.
It kind of makes sense on a conversational level. Propagators are joined at vertices, and at each vertex propagators can split into other propagators, sort of like a double slit experiment where at each screen the possible paths split into two. The location of the screens or vertices are integrated over all space, like a path integral. Real particles (say at position x) correspond to sources that inject their physical location at one end of a propagator J(x)delta(x,z), and that equation kind of says that the source at x propagates to z and the amplitude is delta(x,z), and then z meets a vertex (double slit), and finally z leads to another real particle at y via delta(z,y)J(y). So you have the amplitude to go from x to y of a real particle as a path integral through all paths z.
Here's the full propagator for the real Klein-Gordan field:
http://en.wikipedia.org/wiki/Propagator#Feynman_propagator
[tex] \ = \left \{ \begin{matrix} -\frac{1}{4 \pi} \delta(s) + \frac{m}{8 \pi \sqrt{s}} H_1^{(1)}(m \sqrt{s}) & \textrm{ if }\, s \geq 0 \\ -\frac{i m}{ 4 \pi^2 \sqrt{-s}} K_1(m \sqrt{-s}) & \textrm{if }\, s < 0. \end{matrix} \right. [/tex]
It's pretty nasty looking, but simplifies considerably if the particle is massless to something like one over the (spacetime) distance squared (for both time-like and space-like intervals if I recall).
The video lectures are not very clear but I found it in the book... thanks... it is as follows.
P(A to B) is ;
A photon has an amplitude to go from a point A in space-time to another point B.
This amplitude, which I will call P(A to B), is calculated from a formula that depends only on the difference in location (X2-X1) and the difference of the time (T2-T1).
In fact, it's a simple function that is the inverse of the difference of their squares, an "interval," I, that can be written as (X2 -X1)^2 - (T2-T1)^2.
E(A to B) is ;
The formula for E(A to B) is complicated, but there is an interesting
way to explain what it amounts to. E(A to B) can be represented as a giant
sum of a lot of different ways an electron could go from point A to point
B in space-time
the electron could take a "one-hop flight," going directly from A to B;
it could take a "two-hop flight," stopping at an intermediate point C;
it could take a "three-hop flight," stopping at points D and E, and so on.
In such an analysis, the amplitude for each "hop"--from one point F to
another point C, is P(F to G), the same as the amplitude for a photon
to go from a point F to a point G.
The amplitude for each "stop" is represented by n, n being the same number
I mentioned before which we used to make our calculations come out right.
"n" is related to the "mass" of the electron.
The formula for E(A to B) is thus a series of terms:
P(A to B) [the "one-hop" flight]
+ P(A to C)*n2*P(C to B) ["two-hop" flights, stopping at C]
+ P(A to D)*n2*P(D to E)*n2*P(E to B) ["three-hop" flights, stopping at D and E]
+ . . . for all possible intermediate points C, D, E, and so on.
Note that when n increases, the nondirect paths make a greater contribution
to the final arrow. When n is zero (as for the photon), all terms
with an n drop out (because they are also equal to zero), leaving only the
first term, which is P(A to B). Thus E(A to B) and P(A to B) are closely
related.
1. What does the QED function E(a to b) represent?
The QED function E(a to b) represents the expected value of a random variable a to b, or the average outcome over a large number of trials.
2. How is the QED function P(a to b) related to E(a to b)?
The QED function P(a to b) represents the probability that the random variable a to b will take on a particular value, while E(a to b) represents the average value of the random variable. They are related through the formula E(a to b) = sum of all possible values of a to b multiplied by their corresponding probabilities.
3. How are QED functions E(a to b) and P(a to b) used in scientific research?
QED functions E(a to b) and P(a to b) are used in a variety of scientific fields, such as statistics, economics, and physics, to calculate and analyze data. They are particularly useful in understanding the likelihood of certain outcomes and making predictions based on data.
4. Can the QED function E(a to b) be negative?
Yes, the QED function E(a to b) can be negative. This occurs when the random variable a to b has a higher probability of taking on negative values rather than positive values. For example, in a study on the stock market, the expected value of a stock may be negative if it is more likely to decrease in value than increase.
5. How is the QED function E(a to b) calculated?
The QED function E(a to b) is calculated by multiplying each possible value of the random variable a to b by its corresponding probability, and then summing all of these values together. This can be represented by the formula E(a to b) = sum of all possible values of a to b multiplied by their corresponding probabilities.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
