QM - Can We Conclude [A,B]=0 with {|a',b'>}?
  • Thread starter Thread starter indigojoker
    observables Qm
7 replies · 3K views
indigojoker
If A and B were observables, and say the simultaneous eigenkets of A and B [tex]{|a',b'>}[/tex] form a complete orthonormal set of base ket. Can we conclude that [tex][A,B]=0[/tex]?
2. The attempt at a solution
Assume [tex]{|a',b'>}[/tex] is incompatible:
[tex]AB|a',b'>=a'b'|a',b'>[/tex] <-- skipped several steps
[tex]BA|a',b'>=a'b'|a',b'>[/tex]
[tex]AB|a',b'>-BA|a',b'>=0[/tex]
[tex][AB-BA]|a',b'>=0[/tex]
[tex][A,B]|a',b'>=0[/tex]
[tex][A,B]=0[/tex]
and so we reach a contradiction. Therefore, we conclude that [tex][A,B]=0[/tex] assuming the simultaneous eigenkets of A and B [tex]{|a',b'>}[/tex] form a complete orthonormal set of base ket.
was this thought process correct?
indigojoker said:
[tex][A,B] |a',b'\rangle =0[/tex]...(1)
[tex][A,B]=0[/tex].....(2)
It is important to mention that vectors [itex]|a',b' \rangle[/itex] form a full basis. Therefore any vector in the Hilbert space can be represented as a linear combination of these basis vectors. Therefore, by linearity, your eq. (1) is valid for any vector [itex]|\psi \rangle[/itex]
[tex][A,B] |\psi \rangle =0[/tex]
Then you can conclude that eq. (2) holds.
Eugene.
dextercioby said:
Yes, but the observables are incompatible, not the vectors. And your LaTex would look better by using "[tex]\rangle[/tex]" instead of ">".
Sorry, you mean I should assume that A and B are incompatible and the do the proof by contradiction right?
Nope, compatibility of the observables is no issue here. And you don't need to use any "proof by contradiction". A direct proof is enough. And that's what you did in post #1 in this thread.
Then I'm not sure what you mean by this:
just wonder, how would this change if [tex]|a' , b' \rangle[/tex] did not form a complete orthonormal set of base ket
