QM: Issues with parity of spherical harmonics and Heisenberg
The discussion revolves around quantum mechanics, specifically focusing on the Heisenberg uncertainty principle and the properties of spherical harmonics in relation to a hydrogen atom state. The original poster presents a problem involving the calculation of variances for the electron's x-coordinate using the given state and hints at the use of commutation relations.
  • Participants explore the use of the generalized uncertainty principle and commutation relations, questioning how to apply the hint regarding the commutator. There is discussion about calculating variances for angular momentum operators and the expected values involved.
Participants are actively engaging with the problem, offering insights into the calculations needed for variances and expected values. Some guidance has been provided regarding the relevance of certain operators and the rationale behind choosing specific ones for the calculations. Multiple interpretations of the problem are being explored.
There is mention of previous calculations related to angular momentum, and participants express uncertainty about the relevance of certain expected values and the choice of operators in the context of the problem.
renec112
Hi physics forms! I'm practicing to for an Quantum mechanics exam, and i have a problem.
1. Homework Statement
I have two problems, but it's all related to the same main task. I have a state for the Hydrogen:
## \Psi = \frac{1}{\sqrt{2}}(\psi_{100} + i \psi_{211})##
where ## \psi_{nlm}##.
Use Heisenberg uncertainty relation to find the lower value for the varians ## \sigma_x ## of possible meassures for the electrons x-cordinate. HINT It can be used without proof that
## [L_z, x] = i \hbar y ##
2. Equations
Heisenberg:
## \sigma_x \sigma_y \geq \hbar/2##
3. My try
Well here is where it gets awkward. I have a very hard time understanding what i can use the hint for.
I could try to isolate ## \sigma_x \geq \frac{2}{\hbar \sigma_p}##
But given the hint is in a commutator i think i should use the generalized uncertainty principle.
##\sigma_A \sigma_B \geq |\frac{1}{2i} <[A,B]>| ##
But then i should look at
##\sigma_x \sigma_{L_z}##
Which makes no sense to me.
I Would very much appreciate your comment, thank you
The trick here is that ##\sigma_{L_x}## is something we can actually compute directly in this state, using the definition $$\sigma_{L_x}^2 = \langle L_x^2 \rangle - \langle L_x \rangle^2.$$ Specifically, you should be able to compute ##\langle L^2 \rangle## without too much trouble, which gives you ##\langle L_x^2 \rangle## by symmetry in ##x## and ##y##; that leaves ##\langle L_x \rangle##, which can be computed without any work at all (why?).
Once you have the exact variance ##\sigma_{L_x}##, you can use the generalized uncertainty relation to find a lower bound for ##\sigma_x \sigma_{L_x}## and solve the inequality for ##\sigma_x##, as you suggested in your solution attempt. At some point, you'll have to compute the expected value ##\langle y \rangle##, which could be kind of nasty, but otherwise this should be straightforward.
Me and my group had a laugh at this, we are just finished doing it and it was very nasty indeed :D
Thank you very much for the comment.
- You mean ## <\sigma_{L_z}^2> ## and not ## <\sigma_{L_x}^2> ## Right?
We have actually calculated ##<L_z## and ##<L_z^2>## from another task. We did it using:
##L_z f^m_l = \hbar m f^m_l##
I'm Curious why you suggest ## <L^2>##? Would you use:
##L^2 f^m_l = \hbar^2 l(l+1) f^m_l ## a
and then exploit:
##L^2 = L_x^2 + L_y^2 +L_z^2 ##
Thanks for helping me out!
Btw, so we are just picking ##L_z## because it does not commute with ##x## ? it's just a bit random to me.
As you suggest, ##\langle L^2 \rangle## is just a way to get at ##\langle L_x^2 \rangle##, which we need to know in order to compute ##\sigma_{L_x}##.
I'm not sure what you mean by your first question--##\sigma_{L_x}## can be calculated exactly, so we don't need to worry about "##\langle \sigma_{L_x} \rangle##."
As for ##\langle L_z \rangle##, your calculation is correct, but this is actually not all that relevant to this question. In particular, ##\langle L_x \rangle \neq \langle L_z \rangle##.
The reason we're choosing ##L_x## is twofold: (1) it doesn't commute with ##x##, and (2) we're in a linear combination of angular momentum eigenstates, which means that ##L_x## should be (relatively) convenient to work with.
Okay i think i understand so we are calculating:
##\sigma_x \sigma_{L_x} \geq |\frac{1}{2i} <[x,L_x]>| ##
and not:
##\sigma_x \sigma_{L_z} \geq |\frac{1}{2i} <[x,L_z]>| ##?
Thank you for helping me.
  • · Replies 0 ·
