Does For All Imply Exists in Quantifier Logic?
  • Thread starter Thread starter Terrell
    Logic Translation
The discussion centers on the correct interpretation of the logical statement regarding married couples and fights. The initial attempt, ∀x∃y(M(x, y) → F(x, y)), suggests that for every person, there exists someone they could be married to and have fought, which inadvertently implies that everyone is married. The correct interpretation is ∀x∀y(M(x, y) → F(x, y)), indicating that all married couples fight, regardless of who they are. The conversation highlights the importance of using universal quantifiers to accurately convey the intended meaning in logical expressions. Ultimately, the distinction between existential and universal quantifiers is crucial for valid logical reasoning.
Terrell
All married couples have fights
let x be a person and y be another person
M(x,y): x is married to y
F(x,y): x have fought y
∀x∃y(M(x, y) → F(x, y)): i read my translation as "For all x, there is some y such that if x is married to some y then x and y have fought each other"
but i found the correct translation to be: ∀x∀y(M(x, y) → F(x, y))... I do not understand where my mistake is. Should the interpretation for using ∀y be for all the partners x had and will ever have?
I'm not sure what your version really means. It almost means:
Everybody is married to someone and fights with them.
Which inadvertently implies everyone is married. But, it really says something like:
For everyone (x), you can find someone (y) such that if x and y are married, then they fight,
But, this sort of logical construction isn't really valid, since once you've found y you have a single pair who are either married and/or fight. There's not really a sense of implication in these cases.
The correct answer that you quote is simple. It says:
For all people (x and y): if they are married, then they fight.
Or, to look at it another way:
Take any two people: are they married? No - there is nothing more to say. Yes - then they fight.
hmm... i don't think that my translation inadvertently means everybody is married since it encloses and "if... then" statement.
No, it doesn't. I said it "almost" says that. In general, if you have something about "all couples", then it must start ##\forall x \ \forall y##. If you start with ##\forall x \ \exists y##, you are automatically heading towards a "for everyone, there is someone else" construction.
Here's an example of why your proposition is not right. Let's assume that ##x## is married to ##y_1## and ##y_2##. The question says nothing about bigamy being forbidden. Let's say that ##x## fights with ##y_1## but not with ##y_2##.
The original proposition says that all married couples fight. If this holds then ##x## must fight with both ##y_1## and ##y_2##. In this case, therefore, the original proposition does not hold.
Your proposition, however, does hold, as for this ##x## you can find ##y_1## who is married to ##x## and they fight.
But, my second point is that your logical construction is not really valid in the first place. Because, you haven't said "they are married and they fight". You have said "if they are married, then they fight", which doesn't work with an existential qualifier.
Your construction involves essentially:
##\exists x: \ P(x) \rightarrow Q(x)##
Which doeesn't really mean much.
Everyone can find someone they could marry and fight with. (That's why its best to stay unmarried or to marry someone whom you won't fight with.)
Likes PeroK
What's the verdict on the construction in the OP? I couldn't figure out a clear meaning for it. Is your post a valid interpretation of the logic?
I would read yours as "for all people x, there exists AT LEAST ONE person y, such that if x is married to y, then x and y have fought."
But what you want to say is that it's true for ALL y. Doesn't matter who the person is.
Note that the solution IMPLIES your statement. If the solution is true, your statement will also be true. This is an example of something in math where sometimes you have a statement (like yours) but which to "strengthen" it. Yes, there exists such a y, but is it true for ALL y? That would be a stronger statement.
-Dave K
Likes Terrell
Do you mean a valid interpretation of the OP's attempted answer ? That can be debated.
I said a person "can find someone they could marry... " instead of "there exists some person y such that if they married y...".
If we take "can find" to mean "can theoretically find" then "can find" could be interpreted as "there exists". If we take "can find" to mean some action that depends on the limitations of person x, then "can find" is a debatable interpretation of "there exists". The limitations would have to be severe. For example, if there is a person x who can truthfully say "I can't find anyone who will marry me", this does not invalidate my interpretation, because my interpretation says "x could marry y", not "x marries y" or "x does marry y". So a possible interpretation of " x could marry y " is "if x hypothetically married y". If there is a person x who "cannot find anyone to marry" his situation presumably makes ##M(x,y)## false, so the implication ##M(x,y) \implies F(x,y)## is true.
-Dave K
As implied above, unless ##x## is married to everyone, then this is vacuously true for every ##y## to whom ##x## is not married.
I meant, in general, does:
##\exists x (P(x) \rightarrow Q(x))##
makes sense, or is it invalid?
Similarly:
##\forall x \exists y (P(x,y) \rightarrow Q(x,y))##
Or, perhaps, it is largely a vacuous proposition?
Not sure what you mean, but maybe it's getting difficult to parse these in English.
If ##x## and ##y## are not married, then the following is vacuously true: if ##x## and ##y## are married, then they fight.
Similarly:
Both are valid logical expressions, but I can't think of any practical use for them in mathematics. On the other hand, there are expressions in common language that, if taken literally, do match those patterns.
For example: "There are some people that would have been ashamed if they took a bribe" - meaning literally that there exists a person x such that if x took a bribe then x was ashamed".
yeah. i thought about the bigamy thing too that i forgot to consider after i posted this question.
PeroK said:
If you start with ∀x ∃y∀x ∃y\forall x \ \exists y, you are automatically heading towards a "for everyone, there is someone else" construction.
did you use "can find" to interpret my interpretation because in order for a person to be ABLE(can) to find a partner, there is no necessity that everybody that exists is a potential partner, but there only needs to be AT LEAST ONE potential partner?
i think you nailed it here. that is exactly what i meant. it is vacuously true for every y to whom x is not married to! also I'm bringing this up in class.
-Dave K
yeah i completely agree with what you said here, but i think that my interpretation, though it does not explicitly say all the y that x is married to, implies IT due to the conditional if y is married to x...?
I'm not sure what you are saying.
##\forall x \exists y (M(x,y) \implies F(x,y))## is not equivalent to ##\forall x \exists y (M(x,y) \land F(x,y))##
##\forall x \exists y (M(x,y) \implies F(x,y))## is not equivalent to ##\forall x \forall y ( M(x,y) \implies F(x,y))##
Likes Terrell
