Undergrad Quantum Computing - projection operators
The discussion centers on demonstrating that the product of two commuting projection operators, P1 and P2, is also a projection operator. Participants clarify that the commutation relation [P1, P2] = 0 implies P1P2 = P2P1, not that their product is zero. The key property of projection operators, P^2 = P, is emphasized as crucial for the proof. The conversation evolves into how to express the mathematical relationships clearly, with participants confirming the validity of their equations. Ultimately, the focus remains on understanding the implications of commutation and the properties of projection operators.
Peter_Newman
Assume ##P_1## and ##P_2## are two projection operators. I want to show that if their commutator ##[P_1,P_2]=0##, then their product ##P_1P_2## is also a projection operator.
My first idea was:
$$P_1=|u_1\rangle\langle u_1|, P_2=|u_2\rangle\langle u_2|$$
$$P_1P_2= |u_1\rangle\langle u_1|u_2\rangle\langle u_2|\neq 0$$
the second expression is not zero if ##\langle u_1|u_2\rangle## are not orthononal.
But I do not really get on with this task, which is why I hope for some advice.
An expression like ##P_1 = |u_1\rangle\langle u_1 |## is for a projection operator that projects any vector on a 1-dimensional line in the state vector space. A more general projection is
##P = \sum\limits_{k} |u_k \rangle\langle u_k |##
where the vectors ##|u_k \rangle## form an orthonormal set.
Likes vanhees71
You're not trying to show that the second expression is zero. You're trying to show that ##P_1 P_2## is a projection operator if ##P_1## and ##P_2## commute.
Do you know what defines a projection operator? That is, if ##P## is a projection operator, can you write down a statement that must be true of it (without writing it out in terms of bras and kets)?
My knowledge of projection operators is similar to what @hilbert2 summarized in his post. I somehow lack the relation to the commutation operator. It would be very nice if you could help me a bit.
So the commutator operator comes to mind. At least I have snapped that at some point:
$$[A,B]=AB-BA$$
So suppose I have the two projection operators ##P_1## and ##P_2##. Since these are orthogonal, the product of these two is 0, which I wanted to say in my first post. But now the connection to what is missing in the task of my input posts (##P_2P_1## would also have to be 0 and therefore can not be a projection operator?).
Did you know that a projection operator ##P## has the property that ##P^2 = P##? In other words, applying it twice is the same thing as applying it once. (This should make sense if you think about what a projection operator means.)
Can you see how this fact might be helpful?
No, that's not true. ##[P_1, P_2] = P_1 P_2 - P_2 P_1##. So ##[P_1, P_2] = 0## just implies ##P_1 P_2 = P_2 P_1##. It does not imply that ##P_1 P_2 = 0##.
The problem statement does not require that ##P_1## and ##P_2## are orthogonal.
Ok, that would have been my alternative hypothesis.
Yes, I have heard of this property before. Unfortunately, I can not quite see how far this property can help me with ##P_1 P_2 = P_2 P_1##
What does ##P^2 = P## look like if ##P = P_1 P_2##?
If ##P=P_1P_2## so ##P^2=(P_1P_2)(P_1P_2)=P_1^2P_2^2##
Peter_Newman said:
If ##P=P_1P_2## so ##P^2=(P_1P_2)(P_1P_2)##
Right.
Peter_Newman said:
##(P_1P_2)(P_1P_2)=P_1^2P_2^2##
How are you obtaining this? The ordering of the factors on the LHS is different than on the RHS, since ##P_1^2 = (P_1 P_1)## and ##P_2^2 = (P_2 P_2)##.
##P^2=P_1P_2P_1P_2=P_1^2P_2^2=P_1P_2=P##
Ok, so does this answer your question in the OP?
Yes, almost. I just do not quite know how to express that linguistically ...
Why do you need to? The equations are clear and straightforward.
Likes vanhees71
Yes, I agree with that a bit, if I see ##P^2=P_1P_2P_1P_2=P_1^2P_2^2=P_1P_2=P##
Here is the above mentioned product already in it ...
@PeterDonis by the way, thanks for the support!
Likes vanhees71
You're welcome!
  • · Replies 0 ·
