arkajad
- 1,481
- 4
Isn't each diffraction pattern a multi slit experiment? There are all kinds of diffracting grids. Or do you mean one or two photons (at most three?) at a time?
taylaron said:To my understanding, the diffraction of electrons in a double silt experiment was completely unexpected by physicists. This experiment resulted in the formation of the particle-wave duality concept which was incorporated into quantum mechanics.
Although I do not have a legitimate reason why, I would be curious to explore the use of a wide range of grating materials as its effects on the diffraction pattern may be as shocking as the original experiment itself. I do not know how or why the interference would act differently, it is simply a matter of curiosity for me.
Back to my original question; (regardless of why…) has the double slit experiment been made using many different slit materials?
Cthugha said:I suggest you re-read section 2.2 of “The Quantum Challenge” by Greenstein and Zajonc where they describe two experiments by Grainger, Roger and Aspect. The first experiment had a beam splitter and photon detectors on each of the two paths. When a single photon went through the beam splitter it was detected on one path or the other, never on both. This, however, does NOT prove that the other path was not taken; what it does prove is that the other path, if taken, was not selected for photon termination/detection. This can be seen by the second experiment of Grainger, Roger and Aspect. Here they sent the single photon through a Mach–Zehnder interferometer and found conclusive proof of a single photon interfering with itself (i.e., traveling both paths). So yes a wave (photon) can sub-divide (follow all paths) and still select only one path for termination/detection.
This is not true. Reread the common literature on the subject. Common antibunching experiments show that single photons are always detected at only one exit port after a beam splitter. If a photon had the ability to subdivide, you could place two detectors behind a beam splitter, fire single photons at it and would expect some coincidence detections due to the photon splitting in two. You never see those effects, so a photon cannot subdivide the way you suggest.
Please note that the signature of a single photon interfering with itself does not mean that it subdivides and travels along both paths. The concept of a well-defined photon path is already ill-defined in this context. It is the probability amplitudes for the several possible events which interfere, not the actual particles themselves. See for example Roy Glauber's Nobel lecture "one hundred years of light quanta" (frrely available in the net) for details.
Unix60959 said:
taylaron said:Is there anything inaccurate information portrayed in this video?
CaPhysics said:You also mention "probability amplitudes" interfering with each other to produce the photon wave effects. But "probability amplitudes" usually refers to the Schrödinger wave equation and you cannot write such an equation for a photon since it has zero rest mass http://en.wikipedia.org/wiki/Photon. If photon behavior was as easily solved as you indicate people would stop writing books about it (and they haven't).
Regards,
CaPhysics
CaPhysics said:Maybe I am missing something here but you state that [in paraphrase] "we have zero evidence that photons split in two (subdivide)." But the post you are refuting says "When a single photon went through the beam splitter it was detected on one path or the other, never on both." So what exactly are you refuting?
Cthugha said:Quantum optics treats probability amplitudes more in a - well - Feynman-path-integral-like way.
The Quantum Trajectory Approach to Problems in Quantum Optics
Principal Investigator Howard Carmichael
Co-Principal Investigator(s)
Recipient Organization University of Oregon Eugene
Summary
A new approach to the physics of open quantum systems emitting photons to the environment is developed using a quantum trajectories method. The averages from this ensemble of trajectories reproduce the results of conventional quantum mechanics. The approach has the advantage that it can simulate real time signals and throws new light on the problems of quantum measurement. Another strength of the trajectory approach is that it is a wavefunction based method, which avoids the problems of the more traditional density matrix techniques. The method will be applied to problems in cavity quantum electrodynamics and the interaction of atoms with nonclassical light. The ultimate hope is a self- consistent theory of quantum measurements in optics.
Quantum Jumps Revisited: An Overview of Quantum Trajectory
Theory
H. J. Carmichael
Abstract: The quantum trajectory theory of photon scattering in quantum optics is reviewed. Two features of the theory which bear closely on issues of interpretation in quantum mechanics are emphasized: (1) there exist different unravellings of a scattering process which reveal complementary aspects of the dynamics in the interaction region, and (2) through the making of records via a stochastic implementation of a formalized quantum jump a self-consistent interface between a quantum evolution (in Hilbert space) and a classical evolution for the records (time series of real numbers) is achieved.
OK, good find. But journals are many and articles accepted are many squared. Are you sure these represent mainstream opinion? And I note some qualifications in both articles.arkajad said:You can write such an equation. See http://www.cft.edu.pl/~birula/publ/APPPwf.pdf" .
CaPhysics said:OK, good find. But journals are many and articles accepted are many squared. Are you sure these represent mainstream opinion?
bdavlin said:So is the act of human observation enough to alter the behavior of the particle? Or is it because we're using energy to observe it and therefore altering what is being observed?
CaPhysics said:OK, good find. But journals are many and articles accepted are many squared. Are you sure these represent mainstream opinion? And I note some qualifications in both articles.
The Feynman approach seems to be better founded.
arkajad said:It is the presence of the measuring devices that changes the evolution of the quantum state vector. Human observation is not important. It can animal observation or no observation at all. Just registration.
chris2112 said:So- just to clarify- someone could setup a detector to detect which slit the particles are going through, never check the data, and see no interference pattern?
A. Neumaier said:No. The detector impairs the interference patterns, no matter whether anyone looks at the data it produces.
morrobay said:Is my understanding of your above statement correct :
That the double slit interference pattern is destroyed based on classical physics alone.
During the detection process using photons or other particles the electrons path is altered causing the interference pattern to vanish for physical reasons only.
And that you are refuting the QM explanation that it is the act of observer knowledge on which slit the electron passed that inhibits the interference pattern.
physics pfan said:Regretfully I find some problems in this post. First, "wave function collapse" is normally equivalent to "collapse of the state vector Ψ" and |ψ|2 gives you the probability of finding an electron in a specific location whereas a photon is subject to Maxwell's equations and the probability of a photon in a location is proportional to the square of the radiation energy density at that location. So I think this post has confused computational ψ waves with real-world radiation energy waves. Not the first time this has happened.
A second problem is the easy identification of photon with particle. There is scant evidence for the photon as particle aside from the lazy assumption that anything traversing space and terminating at a point must be a particle. As to why this "particle" should exhibit all sorts of wave behavior before its "particle" termination, many don't want to be bothered with that.
So the sensible answer as to why a photon can pass through both slits is that it is a wave and a wave, unlike a particle, can subdivide (and later rejoin and interfere).
The real question is why an electron can do the same thing. That is 1) tied up with the wave nature of the moving electron and 2) the subject of a different thread.
Regards,
PP
zketrouble said:This doesn't take into account another important discovery of science: a photon can bounce into an electron and cause it to move out of its way. Thus, this wave has momentum, and for it to have momentum, by definition it has mass.
