- 29,189
- 20,848
Motore said:Here is a (pop sci) video, arguing for a Principle of indiference as a possible solution of the derivation of the Born rule in MWI. I know is pop sci but you have a link to a pdf by Taha Dawoodbhoy (that is itself a derivation of the concept from Zurek and Carroll) that explains it in more detail.
I think I understand the argument. The idea is that all quantum states can be broken down to a number of equally likely basic states. This reduces probability to counting the states and - due to the equal likelihood - the emergent probabilities are explained without probabilities in the fundamental branching. This is a relatively simple argument.
Let's take the example of radioactive decay, where (say) the probability of decay in the next second is 0.1. The argument is that somewhere buried in the weak interaction is a process with 10 equally likely outcomes: 9 of which entail no decay; and, only one of which entails decay. Then, you have 9 worlds with no decay after a second and only one world where you have decay. All the non-equally-likely probabilities emerge from this fundamental non-probabilistic or equally-likely fundamental branching.
A similar argument would apply to scattering processes, where you would postulate a set of fundamental equally-likely interactions (buried somewhere in the theory), that eventually produce unequal probability amplitudes for different scattering angles.
In summary:
The basic idea is quite simple.
There's no question that probabilities could be produced by a fundamental uniform or equally likely discrete branching into all possible outcomes. Although, I can see some issues with discrete branching when you look at all possible interactions at the same time. Using infinite branching at the fundamental level, I imagine the numbers could be made to work out. Even if discrete branching cannot be made to work across all interactions simultaneously.
The bigger problem, IMO, is justifying the idea of this equal branching on a fundamental level. It's not clearly supported by the mathematics of scattering processes and Feynman diagrams etc. That said, the path-integral formulation may, in fact, be quite close to this idea.
