Quantum Field Operators for Bosons
4 replies · 2K views · last reply
knowwhatyoudontknow
TL;DR
Trying to better understand Quantum Field Operators
Consider the field creation operator ψ†(x) = ∫d3p ap†exp(-ip.x)
My understanding is that this operator does not add particles from a particular momentum state. Rather it coherently (in-phase) adds a particle created from |0> expanded as a superposition of momentum eigenstates states, exp(-ip.x), at x, to a particle (if it exists) expanded as a superposition of basis states, exp(ip.x') at x'. The probability amplitude at x is then:
∫d3p exp(-ip.x)/√2π exp(ip.x')/√2π = δ(3)(x - x') which is an eigenvalue of position
Is this the correct interpretation of how things work? Sorry, if my question is a little redundant, but I am just starting out with QFT.
If you are talking about non-relativistic free particles, it's correct. Here ##\hat{\psi}(x)## annihilates a particle at position ##x##.
Thanks. If a particle exists at x1 and another is added at the same point is it also fair to say that the resulting state is the ⊗ product of the 2 wavefunctions?
Be careful! The field operators are distribution valued operators due to the equal-time canonical commutator (bosons) relation
$$[\hat{\psi}(t,\vec{x}),\hat{\psi}^{\dagger}(t,\vec{y})]=\mathrm{i} \delta^{(3)}(\vec{x}-\vec{y}).$$
That's why squaring an operator at the same point is ambigous. It's of course the same singularity as in
$$\langle \vec{x}|\vec{y} \rangle = \delta^{(3)}(\vec{x}-\vec{y}).$$
There's a cure for that: Use "smeared" position states, i.e., true square integrable functions, i.e., instead of a position eigenstate ##|\vec{y} \rangle## you can use a Gaussian wave packet ##|\phi_{\vec{y}} \rangle## with
$$\langle \vec{x}|\phi_{\vec{y}} \rangle=N \exp\left [-\frac{(\vec{x}-\vec{y})^2}{4 \sigma^2} \right].$$
Then you deal with realistic "position eigenstates", i.e., with a particle in a well-defined small region around the point ##\vec{y}##. Then you can have of course easily two bosons "at the same place" in this "smeared" sense, i.e., taking into account the necessarily finite accuracy you can localize any particle.
Understood. I have read about the difficulties of using δ functions in this context. Smearing makes sense. I have also heard about using 'rigged' Hilbert space as a possible alternative.
