Quantum harmonic oscillator inner product
1 reply · 3K views · last reply
Dazed&Confused
Using the equations that are defined in the 'relevant equations' box, show that
$$\langle n' | X | n \rangle = \left ( \frac{\hbar}{2m \omega} \right )^{1/2} [ \delta_{n', n+1} (n+1)^{1/2} + \delta_{n',n-1}n^{1/2}]$$
$$\psi_n(x) = \left ( \frac{m \omega}{\pi \hbar 2^{2n} (n!)^2} \right )^{1/4} \text{exp} \left ( \frac{-m \omega x^2}{2 \hbar} \right )H_n \left [ \left ( \frac{m \omega}{\hbar} \right )^{1/2} x \right ] $$
where ##H_n## are the Hermite polynomials.
The questions asks you to use the useful relations:
$$ H_n^{'}(y) = 2nH_{n-1}$$ $$H_{n+1}(y) = 2yH_n -2nH_{n-1}.$$
I think that the following is also needed:
$$\int_{-\infty}^{\infty} H_n(y)H_{n'}(y) e^{-y^2} dy =\delta_{nn'}(\pi^{1/2}2^n n!).$$
Here ##yb = x## where $$b = \left ( \frac{\hbar}{m \omega} \right)^{1/2}.$$
Since $$| n \rangle = \int_{-\infty}^{\infty} | x' \rangle \langle x'| n \rangle dx'= \int_{-\infty}^{\infty} | x' \rangle \psi_n(x') dx',$$ $$ \langle n' | X | n \rangle = \int_{-\infty}^{\infty} \int_{-\infty}^{\infty} \langle x | x' \rangle x' \psi_{n'}(x) \psi_n(x') dx' dx.$$
This becomes $$\int_{-\infty}^{\infty} x \psi_{n'}(x) \psi_{n} (x) dx. $$
Substituting into ##y##, we have $$b^2 A_n A_{n'} \int_{-\infty}^{\infty} ye^{-y^2} H_n(y) H_{n'}(y) dy. $$
Using the relations, this becomes $$b^2 A_n A_{n'} \int_{-\infty}^{\infty} \frac12 H_{n+1} H_{n'} e^{-y^2} + n H_{n-1} H_{n'}e^{-y^2} \ dy.$$
I'm unsure how to write these integrals. In particular, which number to choose as the ##n## corresponding to the useful integral.
Ok if I write it like this $$b^2 A_n A_{n'}( \delta_{n',n+1} [\pi^{1/2} 2^n (n+1)!] + \delta_{n',n-1} [\pi^{1/2}2^{n-1}(n-1)!]).$$
The product ##A_nA_{n'}## is $$ \frac{1}{b \pi^{1/2}} \frac{1}{ 2^{n'/2} 2^{n/2} (n!)^{1/2} (n'!)^{1/2 } }.$$
If you replace ##n'## with ##n+1## in the first term and ##n'## with ##n-1## in the second, you get
$$\frac{b}{\sqrt{2}} [ \delta_{n',n+1} (n+1)^{1/2} + \delta_{n',n-1} n^{1/2}],$$ which is the correct answer. This makes sense to me, but is it correct?
