Quantum imaging with undetected photons - adding of states
The discussion centers on the paper "Quantum imaging with undetected photons," specifically addressing the creation and interference of idler photons at nonlinear crystals NL1 and NL2. Participants clarify that while down-conversion events produce idler photons, the probability of simultaneous photon production at both crystals is negligible, preventing the formation of a two-photon state. Instead, the system exists in a superposition of states, allowing for interference at beam splitter BS2. This understanding resolves the confusion regarding the interaction of states |c⟩ and |e⟩ in the context of quantum imaging.
  • Understanding of quantum optics principles, particularly photon down-conversion.
  • Familiarity with beam splitter operations and their role in quantum interference.
  • Knowledge of quantum state superposition and measurement in quantum mechanics.
  • Basic comprehension of nonlinear optical processes and their applications.
  • Study the principles of photon down-conversion in detail, focusing on nonlinear optics.
  • Learn about quantum interference effects in beam splitters and their implications in quantum imaging.
  • Explore the mathematical framework of quantum state superposition and its applications in quantum mechanics.
  • Investigate the latest advancements in quantum imaging technologies and their experimental setups.
Researchers in quantum optics, physicists specializing in quantum mechanics, and professionals involved in developing quantum imaging technologies will benefit from this discussion.
Sonderval
I have a question concerning the paper "Quantum imaging with undetected photons".
http://arxiv.org/abs/1401.4318
In the schematic (Fig. 1) a photon (idler) is created at NL1 and passing the object at O to be reflected further to NL2.
It is then stated in the paper
"By reflection at dichroic mirror D2, the
idler from NL1 aligns perfectly with idler amplitude produced at NL2,
|d\rangle_i \rightarrow |f\rangle_i"
However, if the incoming green laser beam at NL2 also creates an identical photon, why is the resulting state not a two-photon state? Why is it permissible to simply add the amplitude of the two idler photons
On page 2, they write "The probability that a down-conversion occurs at each crystal is equal and very low so the chance that more than one pair of photons is produced at a given time can be neglected."
This doesn't mean only that cases where two or more pairs are produced in a single crystal can be neglected, but also cases where pairs are created in both crystals simultaneously. So you never have a two photon idler state but only single idler photons and you don't know whether a photon comes from one crystal or the other because both crystals produce idler photons in state |f>.
That's at least the impression I got from skimming the relevant part of the paper.
@kith
Thanks a lot for finding this - I was reading the nature version, where this sentence is missing (nasty nature's space restrictions). I think I get how it works now.
O.k.,, after thinking again, I don't get it at all.
If you never have simultaneous production of photons at NL1 and NL2, how can the states |c⟩ and |e⟩ interfere at BS2 (i.e., how can there ever be two photons at the dashed vertical line in Fig. 1)?
If you never have simultaneous production of photons at NL1 and NL2, how can the states |c⟩ and |e⟩ interfere at BS2? (i.e., how can there ever be two photons at the dashed vertical line in Fig. 1)
Let's look at the most simple case first. Remove all crystals and dichroic mirrors. Also let's assume that the green laser is a single photon source (which it isn't because regardless of intensity, lasers produce coherent states).
So we only have a single photon, a beam splitter and a beam combiner. How would you describe the situation at the dashed vertical line now? What exactly goes wrong if you apply the same description to the more complicated case?
(Also an answer to your last question is that signal and idler photons come in pairs. So if a down-conversion event is triggered in one of the crystal, there will always be two photons at the dashed line. But I don't think that this is the issue.)
@kith
Thanks for the help. I think I got it now, here is my current understanding:
"if a down-conversion event is triggered in one of the crystal, there will always be two photons at the dashed line"
If down-conversion is triggered at, say NL1, I will have a photon at c and one idler f, but no photon e.
If down-conversion is triggered at NL2, I'll have a photon e and f, but not c. This is what I also see in eq. (1) of the paper - the f-state occurs together with either c or e.
So the system is actually in a superposition of states, one with a signal photon at c and one with a signal photon at e, because we do not know which of the two ways actually happened. (The same as in a standard double-slit.)
And then I get interference between these two possibilities to get to eq. (2).
Is this the trick?
Yes, this sounds good to me.
Thanks a lot.
  • · Replies 32 ·
  • · Replies 21 ·
