Chemist@
- 115
- 1
How is a dimension defined in quantum mechanics?
I'm not sure I understand the question. The positive integers are the numbers 1,2,3,... and so on. Does that answer your question?Chemist@ said:What do you mean by the positive integer?
That refers to the dimension of spacetime. Spacetime is defined as a smooth manifold, not as a vector space. The simplest way to explain the dimension of smooth manifold is to say that it's the number of coordinates that a coordinate system assigns to each point in its domain.Chemist@ said:What are dimensions in the string theory then? I think there are 11.
I suppose so, but this notion is never given a precise meaning in math books. There's no definition that appears in math books that allows you to pick a specific line, vector or direction and say "this is a dimension". The precise definitions look like the statements I've made above. In the context of vector spaces, it has to do with linear independence. (How many members can a linearly independent set have?) In the context of manifolds, it has to to with how many real numbers a coordinate system associates with a point.ArtistIC said:Isn't a dimension meant to be an independent vector that cannot be described or calculated by another one (i.e. being vertical to another vector(s) ?
They just get more noticeable the smaller region of space you're looking at, like how the thickness of a wire get more noticeable when you zoom in on it.ttakacs said:In microphysics one can met 11 or even more dimensions while macrospace is of 3(+1) dimensional. Is there any transition between them and is this transition is continuous or discrete?
As far as I know, the number is fixed.ttakacs said:At quantum level we are facing fluctuations of physical variables. What is the official contemporary standpoint: could -in principle- the number of space dimensions itself fluctuate? (I guess the calculation from uncertainty relations is not adequate here.)
