Quantum Mechanics - Infinite Potential Well
The discussion focuses on a particle trapped in an infinite potential well, specifically analyzing its wavefunction and energy states. The wavefunction at time t=0 is given as ψ = 1/√(2a) for -a < x < a, and the energy levels are defined by the equation E_n = n²ħ²π²/(8ma). The probability of the particle having an energy of 9ħ²π²/(8ma²) is derived by projecting the initial wavefunction onto the appropriate cosine function, with the sine solution being invalid due to the even parity of the well.
  • Understanding of quantum mechanics concepts, specifically infinite potential wells.
  • Familiarity with wavefunctions and their normalization.
  • Knowledge of energy quantization in quantum systems.
  • Proficiency in mathematical techniques for projecting functions and calculating probabilities.
  • Study the normalization of wavefunctions in quantum mechanics.
  • Learn about the implications of parity in quantum systems.
  • Explore the mathematical techniques for calculating projections of wavefunctions.
  • Investigate the differences between sine and cosine solutions in infinite potential wells.
Students and professionals in physics, particularly those studying quantum mechanics, as well as educators seeking to clarify concepts related to infinite potential wells and wavefunction analysis.
TheBaker
A particle is trapped in an infinite potential well, with the infinite walls at ±a. At time t=0, the wavefunction of the particle is
\psi = \frac{1}{\sqrt{2a}}
between -a and a, and 0 otherwise.
Find the probability that the Energy of the particle is \frac{9 \bar{h}^2 \pi^2}{8ma^2}
E_n = \frac{n^2\bar{h}^2\pi^2}{8ma}
\psi = A \cos{\frac{(2r+1) \pi x}{2a}} for |x| < a
\psi = 0 otherwise
I've calculated the above equations, but I'm unsure how to get from them to the probability of the particle having a certain energy. This could be really simple and it's me just having a brain dead moment, but any help would be very much appreciated.
btw there is also a sin solution with an argument (in your notation) 2r(pi)x/a
personally I prefer the notation n(pi)x/a n even
however the cos solution you wrote is the one you want with r=1, that 2r+1 thing is just a way of writing n so that n is always odd.
so just take the projection of psi at t=0 on your cos function and square the answer
The sin solution isn't valid because this well has even parity (i.e. it's symmetric).
How do I find A? Presumably I need to use the initial condition of Psi, but I found when doing that that A is x dependent, when it should be a constant.
