Quantum mechanics - spin operator eigenvalue probability?
The discussion revolves around the calculation of the probability of measuring the y-component of spin for a spin-1/2 particle, given its state in the Sz eigenbasis. The participant is unsure if the vector u, expressed in the Sz basis, can be used in the eigenvalue equation for Sy, questioning whether the two spin operators commute. It is clarified that S_y and S_z do not commute, which means u is not an eigenstate of S_y, complicating the probability calculation. The conversation also touches on the correct normalization of eigenstates, emphasizing the importance of using the conjugate in calculations. Ultimately, the participant is left needing to find a suitable representation of the state in the Sy eigenbasis to determine the desired probability.
jeebs
Hi,
I have this problem on a past exam paper I am having some trouble with:
"in the conventional basis of the eigenstates of the Sz operator, the spin state of a spin-1/2 particle is described by the vector:
u = \left( \stackrel{cos a}{e^i^b sina} \right) where a and B are constants.
find the probability that a measurement of the y-component of the spin of the particle will yield the result 0.5\hbar ."
For the life of me I cannot work out how to write out matrices legibly on this thing, so I will summarize what is bothering me. I am given pauli matrices \sigma_x_,_y_,_zthat I cannot write out properly, and the spin operator is given by S_i = i\hbar\sigma_i.
In the question I am given the vector u, which is apparently expressed in the basis of Sz eigenstates.
Am I justified in putting this vector u into an eigenvalue equation S_{y} u = a_{y} u ,
where ay is my eigenvalue, when the vector I would be operating on is made from a basis of eigenstates of another operator (Sz)?
I tried this and got two equations for ay, neither of which gives a_y = 0.5\hbar.
does this mean I can conclude that there is zero probability of finding the y-component of the spin being equal to 0.5\hbar ?
or do I somehow have to wangle it so that I get another vector (not u) that is in the Sy eigenstate basis?
thanks.
PS. sorry, this crazy thing will not let me change something 5 lines up where I should have said
"Am I justified in putting this vector u into an eigenvalue equation S_y u = 0.5\hbar u"
You tell me. If u is an eigenvector of S_z, is it also an eigenvector of S_y[/itex]?
are you actually asking me, do these two operators commute? and if their commutator [Sy, Sz] = 0, then yes they do?
is that right, if the eigenvector of one operator is equal to the eigenvector of another, then the operators commute?
Yes. So, do S_z and S_y commute?
not by my calculations, although I just woke up 5 minutes ago. I get [Sy,Sz] is equal to
(hbar^2)/4 multiplied by a 2x2 matrix containing zeros on the leading diagonal and 2i elsewhere.
Right, they don't commute; [S_y,S_z]=i\hbar S_x. So, u is clearly not an eigenstate of S_y.
What are the eigenstates of S_y?
i got that one of them was the column vector, say, x:
x_1
ix_1
and the other vector y:
y_1
-iy_1
but I was not convinced by this because, if the upper component is say, x1, and I choose x1 = 1, then if I go to normalize it i do
1/sqrt[(1^2) + (i^2)] = 1/(1-1) = 0, so how can this be right if I am getting a normalization constant of zero?
You forgot to take the conjugate. You should be calculating \langle x|x \rangle = x^\dagger x, not x^T x.
