I Question about an "exact" distribution function
The discussion centers on the implications of a microscopic distribution function in phase-space defined by delta-functions, specifically regarding the time evolution of this function in the absence of particle creation or destruction. It is noted that the equation derived from phase-space conservation leads to the conclusion that the total number of particles remains constant, as dictated by Liouville's theorem. The importance of ensemble averaging over phase-space trajectories is highlighted, suggesting that without this averaging, the left-hand side of the equation does not represent a valid phase-space distribution function. The conversation emphasizes that the inquiry is not rooted in statistical mechanics but rather in the exact equations of motion for a particle system. Overall, the discussion seeks clarity on the relationship between the exact distribution function and its time evolution without statistical averaging.
dRic2
Suppose I have an exact microscopic distribution function in phase-space defined as a sum of delta-functions, i.e
$$F( \mathbf x, \mathbf v, t) = \sum_{i} \delta( \mathbf x - \mathbf x_i ) \delta (\mathbf v - \mathbf v_i )$$
Can I conclude that, in absence of creation/destruction of particles,
$$ \frac {dF( \mathbf x, \mathbf v, t)}{dt} = \frac {\partial F} {\partial t} + \mathbf v \cdot \frac {\partial F} {\partial \mathbf x} + \mathbf a \cdot \frac {\partial F} {\partial \mathbf v} = 0$$
where ## \mathbf a = \frac {d \mathbf v}{dt}## Note that here no statistical averaging is involved.
I found that this is "trivially" derived from phase-space conservation, but although I get a feeling for it, I don't see it so clearly.
Thanks
Ric
Maybe something like this?
Consider a volume ##\tau## in the case space. Then ##\frac {dN \tau}{dy} = 0## because the total number of particles can not change. Then differentiation of the product yields
##\frac {dN}{dt}\tau = -N \frac {d\tau}{dt} = 0## because Liouville's theorem tells that phase space behaves as an incompressible fluid, so the volume element must be unchanged.
In the OP the most important thing is missing in the intial equation, namely the (ensemble) average over the phase-space trajectories ##(x_j(t),v_j(t))## (though I'd prefer ##p_j## rather then ##v_j##).
My question is what happens if I do *not* perform an ensemble average.
This is not statistical mechanics just yet, it's just a question about the *exact* equation of motion for a system of particles
Then I don't understand what you are aiming at. Without an averaging the left-hand-side of the equation is not a phase-space distribution function.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
