Question about black bodies, emissivity.
  • Thread starter Thread starter bulbasaur88
    bodies Emissivity
1 reply · 2K views
bulbasaur88
Imagine a diamond sphere radius of 1 cm traveling in space far from any heat sources. Embedded in the center of the sphere is a magic heater that can produce 0.3 W for an indefinite amount of time.
If the emissivity of the surface is zero, what temperature does the sphere reach? Why?
The answer is infinite temperature. I don't understand this. If emissivity is zero, doesn't that mean the body doesn't emit OR absorb any heat? I would think that the answer is that it would not reach any temperature... Can somebody explain to me why it would be infinite temperature? Is it because the time factor?
I'm guessing that, because the emissivity is zero, there is no way for heat energy to escape from the diamond through radiation. So heat keeps building up indefinitely at a rate of 0.3 J per second inside the diamond, reaching infinity after an infinite amount of time. If the heat capacity of the diamond is finite, then the temperature at that time is infinite, since, (temperature) = (heat energy) / (heat capacity)
