Question about collisions -- Knife point piercing a ball of clay
The discussion revolves around the dynamics of collisions, specifically examining the interaction between a falling object (a ball of clay or steel) and a knife point. Participants explore concepts related to force, impulse, and the behavior of deformable materials during collisions.
  • One participant questions whether the knife's point would need to withstand the entire force of the falling clay or just a portion before penetrating it.
  • Another participant introduces the equation F = M*A to discuss the force exerted by the falling clay.
  • There is a suggestion that if the ball were made of high strength steel instead of clay, the knife would face greater challenges due to the increased hardness and density of steel.
  • Participants discuss the concept of impulse, noting that it involves force exerted over time, which could affect the severity of the collision.
  • One participant mentions that when one or both masses can deform, the impact time is spread over a longer duration, potentially reducing peak forces experienced during the collision.
  • Another participant clarifies that the net force on the clay will differ from the force on the knife tip during the collision, emphasizing that force describes interactions between objects.
  • There is a distinction made between kinetic energy and momentum, which can be associated with a single object, versus force, which describes interactions.
Participants express differing views on how force is transmitted during the collision, with some believing the knife tip experiences all the force initially, while others argue it only experiences a portion. The discussion remains unresolved regarding the exact nature of force interactions in this scenario.
Participants have varying levels of understanding of physics concepts, leading to different interpretations of force and impulse. The discussion includes assumptions about the mass and material properties of the objects involved.
Decaff
I have a question regarding the collision of two objects, specifically something heavy falling on something with a point. For example, if a 50lb ball of clay fell from 10 meters onto the point of a knife, would the knife's point have to withstand the entire force of the clay before the blade could plunge into the clay?
Welcome to PF. :smile:
What are your thoughts so far? What do you know about collisions between deformable materials?
What does this mean?
I don't know a whole about physics, so bear with me.
F = M*A, so the falling clay has force. My question is, would the tip of the knife be subject to all of that force or just a portion of it before the knife dug into the clay.
What if the ball were made of high strength steel instead of clay? Can you say what you think that difference would make?
Well, I'm not very experienced with physics, and this topic comes from a conversation I had with a friend. I know F = M*A, so the falling clay has Force. My friend thinks the knife point would be hit by all that force, while I thought the smaller area of the knife point would only subject it to some of the force before it digs into the clay.
I think the hardness and density of the steel ball would be too much for the knife to handle.
Exactly! Why? What is the difference between the steel ball and the clay ball?
Also, have a look at this information from Wikipedia about the most relevant consideration, which is "impulse", not just "force". The impulse involves the force exerted over time (shorter time means higher impulse):
https://en.wikipedia.org/wiki/Impulse_(physics)
I assume the knife fairs worse against the steel ball because it's heavier, which increases the force. As for the impulse, from my understanding, the steel ball would have a high impulse while the clay ball might have a lower impulse.
I was assuming clay and steel balls of equal mass, since your question seems to be about the deformability of the falling mass.
Yes. When one or both of the masses in a collision can deform, that spreads the impact time over a wider time interval, which lessens the impulse and the severity of the collision. That's why cars are designed with "crush zones", to lower the peak forces felt by occupants of the vehicle during collisions. Lower peak forces translate directly into less severe injuries for vehicle occupants, and similarly, into less severe crush forces on the knife in your falling clay ball scenario.
Does that make sense?
I was assuming clay and steel balls of equal mass, since your question seems to be about the deformability of the falling mass.Yes. When one or both of the masses in a collision can deform, that spreads the impact time over a wider time interval, which lessens the impulse and the severity of the collision. That's why cars are designed with "crush zones", to lower the peak forces felt by occupants of the vehicle during collisions. Lower peak forces translate directly into less severe injuries for vehicle occupants, and similarly, into less severe crush forces on the knife in your falling clay ball scenario.
If the balls are equal mass, then the steel ball would deform less, causing more force in the collision due to the objects not giving any "leeway," similar to the "Crush Zones" of cars. But the Clay ball being softer, gives way to the knife, which means less force is applied?
Force over time. Impulse...
Thanks, I think I have it down now.
Impulse affects the peak forces.
The ##F## in ##F=ma## is not a single force. It is the net force. The net force on the clay will almost always be different from the force on the tip of the knife.
You have the wrong idea about force. Force is not something that an object has. Actually there is no force if you have only one object. The force is describing the interaction between two objects. The falling ball, before touching the knife, only interacts with the Earth so there is a force describing this, the weight of the ball. And an equal and opposite force acting in the Earth. If we neglect the interaction with te air, this weight is the net force and will determine the ball's acceleration.
As the ball touches the knife it interacts with the knife so there will be another force acting on the ball (and on the knife) due to this interaction. This force may increase and decrease during the interaction but it is not something that the ball had before the interaction and is now applying it to the knife. The net force on the ball will now be composed from the weight and the contact force with the knife and this will determine the acceleration of the ball by Newton's second law.
The quantities that may work closer to your idea are kinetic energy and momentum. Those can be associated with a single object so it make sense to say "the ball has kinetic energy" or "the ball has momentum". But not "the ball has a force".
  • · Replies 35 ·
28K
