Does causality become relative in spacelike-separated entanglement measurements?
6 replies · 2K views
Loptyur
Hello everyone !
I am new on this forum and I am here because, while I was learning quantum mechanics, I have noticed something strange.
Indeed, if we take a pair of entangled particules, we know the measures of these two particules are correlated. But if the interval between these measures is spacelike, we cannot say which one is the first (there exists a reference frame with a particular order but there is also a reference frame with the opposite order). But in this case, the first measure establish the second one. Let's call A and B the two measures. If in some reference system we have A then B, so A implies B. But in some other reference system, we have A before B, so that B implies A. This way, can we state that causality is relative to the reference frame. We must note that it does not create any retrocausality paradox, thanks to the no-communication theorem.
Is there a problem in my reasoning ?
Is it acceptable to say that absolute causality does not exist in our world ?
Or maybe is the interpretation (the one I use here) false ? This situation is trivial with the Everett interpretation.
Thank you for filling in the gaps in my understanding of QM !
No, that is not correct. The measurements commute--that is, their results do not depend on which one occurs first. (This has to be the case because, as you point out, the time ordering of the measurements--which one occurs first--is frame-dependent, and no actual physical result can depend on anything that is frame-dependent.) So you cannot say that either measurement "establishes" the other. All you can say is that their results are correlated in the way the entangled wave function predicts.
No, we can't, because we can't say that either measurement result causes the other. See above.
It's not clear what interpretation of QM you think you're using. But your reasoning is false as noted above.
Reply
It's better to think of an entangled system of two particles. The particles are not independent. A measurement of either particle is a measurement of the system.
There is no causality, because the particles are part of the same system.
Reply
Neither causes the other.
Reply
I cannot prove that that claim is wrong, but that doesn’t mean that I have to accept it. Causality is such a useful organizing principle and so essential to my understanding of the world around us that I’m not giving it up so easily.
Cause and effect relationships are by definition asymmetrical; the relationship between spacelike-separated measurements of entangled pairs is symmetrical. That and the no-communication theorem are enough to convince me that whatever is going on isn’t a causal relationship.
Of course this invites the question, what is really going on here? And as is frustratingly often the case, QM refuses to answer that question.
Reply
  • Love
Picturing Quantum Processes said:
10.2.1 Causality​
Causality is an extremely important postulate for quantum theory which nevertheless has an extremely simple interpretation:
If the output of a process is discarded, it may as well have never happened.
10.4 Historical notes and references​
Causality, although it plays a very central role in this book, was the last one to enter the picture. Its importance became clear from the information theoretic axiomatization of Chiribella et al. (2010, 2011).
Chiribella, G., D’Ariano, G. M., and Perinotti, P. 2010. Probabilistic theories with purification. Physical Review A, 81(6), 062348.
Chiribella, G., D’Ariano, G. M., and Perinotti, P. 2011. Informational derivation of quantum theory. Physical Review A, 84(1), 012311.
From
Coecke B, Kissinger A. Picturing Quantum Processes: A First Course in Quantum Theory and Diagrammatic Reasoning. Cambridge University Press; 2017.
Relativity gives casual structure based on light cones. One must be quite careful in assigning "reality" to global planes of simultaneity based on "frames of reference".
What I mean is the points A and B in spacetime are spacelike separated. This space like separation is an invariant geometrical fact and is preserved in all frames of reference.
Any frame of reference will say "A and B are spacelike separated" and there's not necessarily a fact of the matter that one came before another or not. There is *no causal relation* between A and B in SR.
If you insist that a plane of simultaneity is real and global (i.e. it's not an artifact of your chosen coordinate system) then you immediately run into the Andromeda paradox.
My take away (and this might not be universally agreed upon) from my understanding of SR and GR is that what is "real" within those theories are the coordinate-independent geometrical facts. And there, the only thing we can say about A and B are that they are causally disconnected.
Maybe the following quote helps:
That no inherent meaning can be assigned to the simultaneity of distant events is the single most important lesson to be learned from relativity.
— David Mermin, It's About Time
So I would say, the precise statement can be made: entanglement allows correlations in space like separated events. Those correlations are stronger than can be explained by any local hidden variable theory (Bell's theorem).
Statements such as A precedes B in frame K or B precedes A in frame K' are imprecise at best and at worst are pure artifacts of holding on too tightly to the reality of coordinate systems (such is my view).
